Old 03-02-2010, 05:38 PM   #1
LandonL
LandonL's Avatar
Soundproofing...What are my options?
I'm trying to go down the cheap, but most effective way to soundproof the cabin of my '67 GMC Truck. It has so much noise coming from the engine bay and transmission that I can't even listen to the radio or carry on a conversation. Should I use any rubberized sound proofing spray, then use some sort of dynamat type material with jute padding or what? What are your opinions and the best possible result?
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 03-02-2010, 06:00 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Soundproofing...What are my options?
The more the merrier! All 3 things you mentioned will help quiet things down. The biggest thing you want to do is make sure you don't miss anything. If any area DOESN'T have sound deadener, even if it's a small area, that will contribute more toward the noise factor. So think "COMPLETE COVERAGE" as you do whatever you are going to do.
FYI, for Dynomat, count on about $200 - $300 to cover the cab and insides of the doors completely. Then add to that whatever else you are going to do. So it will cost you a little money, but as you know from not having it, it is WELL worth it! Especially if you sell it. The guy that bought mine couldn't believe how quiet it was inside. Good luck!
69GMCLonghorn is offline   Reply With Quote
Old 03-02-2010, 06:03 PM   #3
capev86
it is not so much having tons of insulation to sound proof, but just something to dampen the natural vibration of and the echo of air riding over large patches of sheet metal.
some cheap rubberized undercoating might work. you don't have to worry as much about moisture getting underneath and making it fall 'cause its on the inside. cheap do it yourself poly bed liner might make a more attractive choice since you don't have to worry about uv exposure. you can get a rhino lining kit at walmart. on the outside, you'd want a high quality product like al's liner or line-x.
capev86 is offline   Reply With Quote
Old 03-02-2010, 06:08 PM   #4
tommys66
can also use this on top of whatever u spray on. Its an adhesive backed duct insulation. I've read great reviews on this product. I purchaced some for my build.
http://www.frostking.com/Lowes/FoamF...Insulation.htm
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 03-02-2010, 06:28 PM   #5
LandonL
LandonL's Avatar
Is there any cheap alternative to Dynamat?
250 L6 .030 over
Old 03-02-2010, 06:35 PM   #6
71402BB
now thats a true COON DOG
yes, check this out http://www.b-quiet.com/ultimate.html
you can compare them both here. I have heard good things! seems to be one of the best ways to quite down your cab.
current project
67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!)
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well...
72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!)
68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!)
67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!)
71402BB is offline   Reply With Quote
Old 03-02-2010, 06:47 PM   #7
LandonL
LandonL's Avatar
I mean, anything I can buy locally.
250 L6 .030 over
Old 03-02-2010, 07:11 PM   #8
evilways
evilways's Avatar
If you have any car stereo installers in your area they should have Dynamat, but your looking at some money on that like the others said. The rubberized undercoat will be less effective as dynamat or other similar products, but is much cheaper and can be found at any auto parts store.
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 03-02-2010, 07:27 PM   #9
69GMCLonghorn
Also, that jute backing stuff helps and isn't too terribly expensive. Or just some really good, dense carpet padding... Depends on how much you want to spend. If you have NO insulation now, anything you do will be an improvement.
