SBC advice for not starting.
So im pretty new to the whole 350 sbc scene. When i put the truck under load for to long it will just die and not want to start up. It will turn over for a few minutes then all I will hear is clicking. I Changed my starter plugs wires and oil. before i go to much farther i wanted to get some ideas of what I may need to do to get her running in tip top shape again....
dazed and confused
Re: SBC advice for not starting.
is it running hot? sounds like it is getting to hot and may not want to start back
members met: redbaron69, billsbowtie,nc67 |
the stock thermostat is disconnected and there is a new one that was installed but dont know how accurate. it stays right at 200 but never goes any further.
How are you putting the truck under a load?
just regular driving for the most part. but other than that going from 45 - 50 mph. thats the last time it died on me. since then i have not had a problem but i have been babying it to and from work. two miles each way.
if you have points they like to b cleaned and gapped same with spark plugs // air cleaners fuel filter in carb and also in gas tanks need regular changes// ground wire connections are good to cleanup for a good flow of juice //
check the timing might be out
Big Red - Now its a SWB!
Sounds like it is cutting out because it's starved for gas. I'd check the fuel filter, crud in the tank or lines, fuel pressure at carb, correct fuel cap (vented or not) and the float level in the carb to start with. I'm not sure on the starting issue but I'd start looking at grounds and other connections as stated above, then check the timing because if you're too far advanced it will crank harder or not at all when hot. Good luck and let us know what you find.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Im starting with the pionts cap and rotor and gaping the plugs to make sure they are all at .35, so far thats what ive heard they need to be at. then the timing. should i switch to an hei system or just keep the points for now?
i'd tune up withj the points to get running and verify the overall condition of the motor and get your fuel system cleaned and flowing right b4 changing out anything
Another area to look into is your charging system. If your battery is in good shape it will run your truck, but once it gets low your truck will start to cut out and even die. When you try to start it back up it won't have the cranking power to start your truck and you will just get clicking from the starter. A simple test to check your charging system is to start the truck and disconect the positive cable from the battery. If your truck keeps runing the charge system is working, if the truck dies then it is runing off just the battery. You can do this or go to a nearby shop and they can check the system for you.
