03-02-2010, 10:26 PM | #1 |
C4 Dropmember and Trailing Arm Conversion Install
So for the last 4 years I have been waiting for the right time to convert my leaf spring suspension to the the trailing arms. I finally got to it in the past few months. I used the CPP 73-87 conversion crossmember, original arms from an older C10 (welded seams), CPP adjustable track bar and some QA1 coilovers.
I have also been building up the parts for the C4 dropmemeber install over the last year + and I finally started the install in December. I upgraded to the C5 Z06 brake setup. I am also upgrading to all new hard lines and SS braided lines as well as the CPP MCPV-1 Master Cylinder. The main intent of the C4 DM and trailing arm conversion wasn't to get the truck on the ground but for performance as that is my #1 goal. Next up on the to do list is the CPP rear disc kit and an extra couple hundred horsepower from a Borg Warner Turbo Check it out:
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 03-02-2010 at 10:28 PM. |
03-03-2010, 12:41 AM | #2 |
Re: C4 Dropmember and Trailing Arm Conversion Install
Flowershop Hip Hop & Street Rods Dropmember 83 Custom Deluxe Almond on Almond 85 Silverado White on Red/Now Chevy LeMans Blue Rendering in Truckin magazine vol 36 no. 11,2010 |
03-03-2010, 01:01 AM | #3 |
super nice job... i put off doing the trailing arms on my long bed til i can weld good enough to make my crossmember... nice to see a 73-87 with trailing arms... i had a talk with jeff at CPP the other day and he is talking to the engineer about designing a crossmember and kit that will work with a long bed. hopefully they will think it is worth it. again awesome job!
03-03-2010, 02:41 AM | #4 |
Would a stock 67-72 crossmember not work? I'm planning on running stock arms and crossmember on mine with the rest of the CPP kit.
Vette stuff looks killer!
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 03-03-2010 at 02:42 AM. |
03-03-2010, 02:44 AM | #5 |
Nice job! It should perform great!
03-03-2010, 08:03 AM | #6 |
I don't think the 67-72 crossmember will work. You will have intereferance with the cab floor. I was working on my own crossmember using 2x6 tubing but it hit the floor. The CPP crossmember is S shaped for that reason. I would have had to mod the floor if I wanted to use my 2x6 crossmember. The CPP crossmember was a nice piece. The only thing I would have liked is the ability to adjust the trailing arms. The CPP piece was worth it, call up Jeff and he will hook you up.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
03-03-2010, 01:40 PM | #7 | |
03-03-2010, 03:59 PM | #8 |
I'm just glad to be here!
Looks good. What sway bar did you use for the front? What was required to do the C5 brake upgrade with the C4 suspension parts?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-03-2010, 07:35 PM | #9 |
Active Member
We have a different track bar mount that we use on the 73-87 trailing arm conversion to get the track bar up closer to the frame. Call Jeff and tell him what you need.
Danny Nix CPP Last edited by DKN; 03-03-2010 at 07:38 PM. |
03-03-2010, 07:45 PM | #10 |
The installed height he has it @ currently looks pretty level (which is optimum??). Wouldn't moving the frame side bracket up closer to the frame cause it to be out of that "parallel to the ground @ ride height" optimum range or do you offer different brackets for each end of the Panhard bar that are specific to the 73-87 conversion?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-03-2010 at 07:46 PM. |
03-03-2010, 07:46 PM | #11 |
It'd be alot cooler if you did
I'm really diggin the whole concept. However, the tabs for the rear coil overs don't look like much. Is there a way you can touchen up the upper and lower mounts?
03-03-2010, 09:06 PM | #12 | |
Kind of hard to see but the cab floor does go below the frame/x-member. Here is the rear of the x-member and the rear cab mount.
03-03-2010, 09:10 PM | #13 | |
You can buy a C4-C5 adapter bracket and hardware. This will also allow you to bolt up the C6 brakes as well, which I will most likely upgrade to at some point if I end up taking it to a track once and a while. The C6 brakes are still a bit expensive though.
03-03-2010, 09:12 PM | #14 |
Does it move both sides up or just the one side that attaches to the frame? I made the bracket based on the ride height and it sits parallel right now.
03-03-2010, 09:16 PM | #15 | |
Active Member
Danny Nix CPP |
03-03-2010, 09:19 PM | #16 | |
I plan on testing them plenty with my 650-700hp turbo motor which will eventually be 1000+hp turbo motor.
03-03-2010, 09:21 PM | #17 |
Active Member
The build is looking good. Nice Pictures too.
Danny Nix CPP |
03-03-2010, 09:22 PM | #18 | |
03-03-2010, 10:46 PM | #19 |
i like how you put the rear coil over outside the frame on that tube you put threw the frame ! what wall thickness is that tube ? and od ? thats what i wanted to do on my 4x4(shocks only) 79 c10.
03-03-2010, 11:49 PM | #20 | |
03-04-2010, 02:30 AM | #21 | |
When you going to get that beast on the road? What was the reason you had to move it forward from CPP's location?
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 03-04-2010 at 02:32 AM. |
03-04-2010, 07:17 AM | #22 | |
I placed the c-member based on the location of the rear. I measure the location when the leafs where on and made sure it was centered on the wheel wells. Good luck with your conversion.
03-04-2010, 09:34 AM | #23 |
Sweet lookin setup I'll have to watch this one.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-04-2010, 10:03 AM | #24 |
Happy to be here
This thread will answer a lot of questions on this conversion. I see members ask about Dropmembers with coil overs. Your install should I show the feasabilty of the application.
I also see the questions about converting 73-87 to trailing arms. This is encouraging to those that are considering the conversion.
03-04-2010, 11:09 AM | #25 | |
Next project: 1970 K10
Wild83C10 - Looks very nice! Could you post some info on the coil-over brackets on the rear end, link or part numbers please? Also, do you think a 67-72 crossmember could be modified to resolve the floor interference problems?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
