Old 03-03-2010, 12:24 AM   #1
erikog76
single wire alternator
i just put in a 100 amp single wire alternator and it's only putting out 12.1 volts i ran a direct line to the positive side of the battery are these alts reliable ?
erikog76 is offline   Reply With Quote
Old 03-03-2010, 01:56 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: single wire alternator
I recently read where this is normal (a disadvantage) with a one wire alternator, because the factory voltage sensing line is no longer present. The following thread explains it pretty thoroughly, but I also read a much more condensed version somewhere else (I can't remember where) that basically said the same thing:
http://www.madelectrical.com/electri...hreewire.shtml
Old 03-03-2010, 11:28 PM   #3
erikog76
you were right on snapped the throttle today and it's charging 14 volts thanks
