Old 03-03-2010, 01:06 AM   #1
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
wider then 295-40-20??
whats up guys, currently im running a 275/40/20 drag radial on the back of my truck temporarily and 255/45/20 in the front which look horrible. I already bought the 245/40/20s for the front but i would like to put a little bit wider tire in the rear my rims are 11.5" wide. any suggestions or pictures you guys can help me with?
staggerd86c-10 is offline   Reply With Quote
Old 03-03-2010, 02:31 AM   #2
staggerd86c-10
Re: wider then 295-40-20??
anyone running 315/35/20s on a square body?
Old 03-03-2010, 09:18 AM   #3
Wild83C10
Wild83C10's Avatar
I ran a 325/50/15 on my stepside and there was definitely enough room for something bigger. I think a 335 would fit, but the backspacing needs to be perfect. I am now running a 295/35/18 and plan on going up to a 305/30 or 315/30 once I run through the 295s.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-03-2010, 11:05 AM   #4
staggerd86c-10
so you think a 315 will be good? i found a good price on some 315/35/20s so i just have some explaining to do to the woman see what she says. I think im going to use the drag radials arent so safe excuse.
Old 03-03-2010, 12:23 PM   #5
nlped
nlped's Avatar
Yepper, they will fit perfectly. I had them on a 10.5" wheel on my previous '86 with a flip kit and they gave me no issue at all. They should be even happier on an 11.5" wheel as that is the optimum width for that size tire.
Tell your lady that some of the truck guys are making fun of your itty bitty tires, and that size does matter! She will agree .
Put some pics up when you get them installed.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 03-03-2010, 01:54 PM   #6
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
I run a 315/35/20 on a 12" wheel..
Nitto now make a 315 in a drag radial also.
Do a search on 315/35/20 on the site.
Grande Rojo is offline   Reply With Quote
Old 03-03-2010, 02:20 PM   #7
staggerd86c-10
any pics? i would like to see how they look on a square, what size were you running up front
Old 03-03-2010, 08:42 PM   #8
Raised On Chevy!
Raised On Chevy!'s Avatar
What wheels are you running on that truck?
Raised On Chevy! is offline   Reply With Quote
Old 03-04-2010, 12:21 AM   #9
Rollinsqrbdy
Rollinsqrbdy's Avatar
I dont know of any sizes but, I do know that your trucks is niceeeee.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 03-04-2010, 08:36 AM   #10
nlped
nlped's Avatar
I had 255/35r20's on mine when I had this combo. Almost exactly the same height as the tire you are gonna be running. You may have to drop it some more
Carter
Old 03-05-2010, 02:29 AM   #11
staggerd86c-10
im going to mount my 245/40/20s in the front and look for a good priced 315/35/20 for the rear, i only have 3" belltech spindles in the front so i was going to cut a coil off the front and the rear i want to remove a couple leafs to bring it down some more.
Old 03-06-2010, 09:56 AM   #12
staggerd86c-10
ok i found a company that makes the matching sedt now all i need are pictures of trucks running these tires, i looked on google but nothing really comes out just alot of pictures of bmw x5s cause thats the size that they come with in the rear.
