Old 03-03-2010, 02:07 AM   #1
dmartin1
dmartin1's Avatar
67-72 a/c acc. on 73-87?
is the air conditioning for the 67-72 chevys different then on the 73-87's?
is anything useable at all?
thanks in advance
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 03-03-2010, 12:02 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 67-72 a/c acc. on 73-87?
the older trucks had the longer compressors but if you had all the brackets you could mount it.. the issue would be the refrigerant lines which MAY have to be custom made, but alot of places can make these up if you search custom hoses. It would prolly be cheaper to use the right set up
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-05-2010, 02:46 PM   #3
92470
The 67'-72' trucks used a different type dryer, compressor, refrigerant lines, a POA valve vs. pressure switch, etc. Totally different system. I personally would look for a junker to take the correct system out of instead of trying to retrofit. You will save yourself much money and frustration doing it that way. Good luck.
92470 is offline   Reply With Quote
