Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-03-2010, 10:27 AM   #1
ozzie50
A-ARM Queston
Are 4 wheel drive and 2 wheel drive Arms the same on a 1991 model? S-10 Found a good set just want to see if they will work
ozzie50 is offline   Reply With Quote
Old 03-03-2010, 01:47 PM   #2
Damien
Damien's Avatar
Re: A-ARM Queston
The 4x4 uses a torsion bar suspension and the 2x4 uses a coil spring. I don't think you will be able to make it work.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 03-10-2010, 07:43 PM   #3
crazycory1
Re: A-ARM Queston
They are completely different. 2wd ones are the same on all s10s from 83 to 04 so you should have no problem finding some.
crazycory1 is offline   Reply With Quote
Old 03-23-2010, 11:59 PM   #4
ozzie50
Re: A-ARM Queston
I was given a set of control arms that the guy said was off a s-10 blazer 2 wheel drive. Will these work? Are there any casting numbers that I maybe able to tell what year they are exactly. Can't beat free unless they care completely wrong. If I posting a pic is there anyone who can give tell me for sure they will work. The reason I am asking is my new bushing looks a lot longer for the lower then the stock ones.
