Old 03-03-2010, 12:37 PM   #1
LANDC
LANDC's Avatar
Which Flywheel?
I am in need of a new flywheel (Manual Transmission ) for my 454 BBC. I know that it has to be an externally balanced one and all that, my question is would a ' Nodular Iron ' flywheel be as good or better as a machined steel one? I can purchase one out of the GM Performance Parts catalogue ( Nodular Iron ) for about a hundred bucks cheaper than a Cenerforce one ( Machined Steel ). I have exhausted all wreckers and racers and have not found a trace of a used one so I think a new one is my only option. Also, I have been told that cast iron ones can crack and or detonate/ fall apart with abuse. I am running 44's and on a good day I believe I am in the neighbourhood of 425 ponies, so naturally it has to stand up to some pounding. Has anyone had any experience with this? Which is better? I am not against springing for the Centerforce one, but a hundred or so bucks could be easily spent elswhere on my ride. Thanks.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 03-03-2010, 02:14 PM   #2
Burt4x4
Burt4x4's Avatar
Re: Which Flywheel?
With my built 454 I used Hayss 30Lb flywheel w/ Luk-ProGold clutch kit
My 454 is about 450hp & 550tq
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-06-2010, 11:46 AM   #3
LANDC
LANDC's Avatar
Re: Which Flywheel?
So I have dropped the tranny out of the way and upon inspection I can see the ring gear isn't totally hooped. I will probably replace it seeing as I can do so easily now. I am running a 12.75 inch flywheel. It is from an internally balanced 305. I purchased a weight that is attachedto a plate that is sandwiched between the flywheel and the crank flange. The plate the weight is on has moved the flywheel away from the starter a little. Is this repositioning of the flywheel slightly back from the starter causing my problem? The problem being the starer sounds like it can't turn the crank over once in a while but always turns through, speeds up and starts.
Old 03-06-2010, 02:43 PM   #4
DieselEater
DieselEater's Avatar
Re: Which Flywheel?
Do yourself a huge favor and buy a new forged flywheel that is made for external balanced applications!!!!!
Your engine will thank you, and your legs will really thank you!
A.........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
