Anybody running Front/Rear disc brake set up? post pics with specs(if u will)
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 03-03-2010 at 12:50 PM. |
![]() Join Date: Apr 2005
Re: F/R disc brake setup
Do you have a link? Price?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Im actually asking if anybody's useing the f/r disc setup on their trucks. Im not selling this product. just using the pic
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 03-04-2010 at 08:53 PM. |
I was just asking for a link to get more information about the setup?
Oh i just googled front & rear disc brackes...n took that photo from there.
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
Coordinator of Synchronicity
![]() Join Date: Dec 2005
Is it for your '67 C-10 ?
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be Last edited by Burb; 03-03-2010 at 05:46 PM. |
Do a search in the suspension forum. There are multiple ways to do it. I personally am going to use the LT1 F-body calipers with a set of CaptianFab's brackets. Lots of guys are using Impala SS calipers but I want an e-brake so I don't have issues getting it inspected in TX.
Yes it is. If i could cut the cost & get MISC pieces from salvage yards i would. Like the guy say Impala parts. I will look deeper into what fits my 67 C-10.
I do want front & rear disc brakes though
this would be a good time to do a 5 lug conversion if you have not already done it.
I haven't yet. im so ready. This is a crucial part of my build. I like the NOSEDIVE stance. 4x6 drop f/r disc setup is ideal for me. They say the truck might lock up because the bed is so light. I wouldn't care,i need to see the RED calipers protruding through the Bonspeed "VINSPEEDS"
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 03-04-2010 at 11:13 AM. |
truck im building for a member is running a very simular kit...
Looks like good quality,whats the cost on a set?
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 03-06-2010 at 10:49 PM. |
#13 |
They tell me i could use a 73-87 chevy c-10 front disc on my truck & a 96 implal rear disc in the rear. Can i do that?
#14 |
Short answer is yes.
#15 |
the 73-87 I think you have to use the spindles and ball joints at the minimum or you can bolt up the whole cross member and be done with it the backs I dont know find out so I can do it
#16 |
How much this would cost? So my parts list should be a 73-87 front cross member & a 96 impala rear end? that'l be genuine chevrolet
#17 |
They do not make this kit for our years. Our price on the Kit for a 2000 chevy pickup and up run $1250.00. pretty pricey
Baer makes a front 14" and rear 13" kit with parking brake We sell them also but here again its pricey Kit 4301389b Front runs $1965 our price Kit 4302126b Rear runs $1243 our price Last edited by mbgmike; 03-07-2010 at 10:51 AM. |
#18 | |
The impala rear is not a direct bolt in. CaptianFab makes some brackets that bolt on and use either an Impala caliper (no e-brake) or a different set of brackets that use the LT-1 F-body caliper (integrated e-brake). You will also need a disc/disc master and proportioning valve. If it's in your budget, There are also kits available as mgbmike has mentioned that include everything you need for a disc/disc conversion. Price is going to vary widely. It depends on what you ultimately end up using and how you source the parts. It could be anywhere form a few hundred to a few thousand. Personally, I am going with the F-body calipers. I have the brackets from Captainfab and can tell you they are quality pieces. I have not completed my install yet so I can't give you all the details. Captainfab F-body brackets. http://67-72chevytrucks.com/vboard/s...d.php?t=382633 If you search the suspension section there are several threads about disc/disc conversions.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-07-2010 at 12:51 PM. |
#19 |
#20 |
You will also need a disc/disc master and proportioning valve. If it's in your budget, There are also kits available as mgbmike has mentioned that include everything you need for a disc/disc conversion. Captainfab F-body brackets. http://67-72chevytrucks.com/vboard/s...d.php?t=382633 If you search the suspension section there are several threads about disc/disc conversions.[/QUOTE] Ok so the front set up 73-87 c-10...done. What type of rear end i need to put the 96 impala disc on it? What i need from the 96 Impala? CaptainFab got the brackets to install then. What else i need to the complete this,master cylinder etc My wheels will be 4' backspacing all around.
#21 |
You really should search the suspension forum. You have to dig a little but I promise you the answers are there. Several members have done this conversion. All you are going to use from the Impala is the rotors.
Lots of info in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=340444
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-08-2010 at 12:15 AM. |
