Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-03-2010, 05:47 PM   #1
raveer2000
raveer2000's Avatar
An fittings
Are you supposed to use any sealant on them at all or are they like hydraulic fittings and seal themselves?
1972 K5 CST. Work in progress. 408CI
1980 K10
raveer2000 is offline   Reply With Quote
Old 03-03-2010, 06:01 PM   #2
jgreene0717
Jason
jgreene0717's Avatar
Re: An fittings
No sealent is needed.
jgreene0717 is offline   Reply With Quote
Old 03-03-2010, 09:51 PM   #3
Wild83C10
Wild83C10's Avatar
Re: An fittings
No sealent. They seal themselves.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-03-2010, 10:13 PM   #4
RatPwrd72
RatPwrd72's Avatar
Re: An fittings
A couple of drops of oil on the threads will keep them from gaulding and easier to tighten if you're using new fittings.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 03-03-2010, 10:13 PM   #5
drag_72
Ready to go fast!!
drag_72's Avatar
Re: An fittings
that have like the flare inverted fittings. no sealant
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 03-03-2010, 11:14 PM   #6
raveer2000
raveer2000's Avatar
Re: An fittings
Thanks Everyone. I already assembled them all but wasn't sure. I figured I would ask before I turn on the fuel pump and had fuel pouring out everywhere.
1980 K10
Old 03-04-2010, 12:18 AM   #7
djracer
djracer's Avatar
Re: An fittings
Its best to check them all under pressure.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-10-2010, 01:51 PM   #8
Jim_PA
Re: An fittings
I used the smallest smear of anti-seize on mine.
Jim_PA is offline   Reply With Quote
