Old 03-03-2010, 06:02 PM   #1
GMC Guy
GMC Guy's Avatar
700r4, how much $$?
i really want to put a 700r4 in my 79. i'm wondering how much it might cost (parts, installation...?) any advice would be great....
would it be cheaper to find a used one and have it rebuilt? or just buy one new.
also would the rear-end gears need to be changed? i think i just have the stock 2.73.
i know a lot of guys run these transmissions, so some feedback would be greatly appreciated too.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 03-03-2010, 06:39 PM   #2
Prong
Re: 700r4, how much $$?
You'll want to regear the diff to at least a 3.42 if you put a 700 in there.
Prong is offline   Reply With Quote
Old 03-03-2010, 07:00 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
I definitely recommend a regearing of the rear end. A 700 R4 and 2.73 gears is a very bad match. The gas mileage and performance will suffer so bad.
Frank
piecesparts is offline   Reply With Quote
Old 03-03-2010, 07:29 PM   #4
GMC Guy
GMC Guy's Avatar
ok so...
1. bolt up trans w/ modified cross-member
2. shorten drive shaft
3. re-gear to 3.73
4. have trans shop adjust TV cable
am i on the right track?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-03-2010, 07:30 PM   #5
D-Day
Live fast, die young
D-Day's Avatar
I have a 700R4 and a 400 engine, 3.73 gears in a '73 crew cab. If there's no wind, I can get 14-15 mpg on the highway.
I had mine installed by a shop back in 2006, and they rebuilt one. Some modifications had to be done to the cross member, all in all I think it totalled around $1400. Finding and making the lockup switch (my end of the job) was a trial and error process from hell.
But if you do install one, make sure you have a lockup. You can run 'em without the lockup, but they don't last as long, the RPM's will be slightly higher, and you won't get as much of the mileage benefits.
In the end, they are very worth it.
D-Day is offline   Reply With Quote
Old 03-03-2010, 07:51 PM   #6
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
well for me i got a well rebuilt trans for 100 bucks but here is a list for 350 to 700r4
cross member is the same,
drive shaft it the same,
steering column is the same,
linkages are the same
what you ill need
transmission ,P
a kit for the lock up I'm get this http://bowtieoverdrives.com/catalog/...php?ITEMID=332
here is there web site full of info http://700r4.com/faq/faq.shtml
and you will need to move your cross member backwards other then that i think your set
doing this in a 1986 c10 now
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-03-2010, 08:50 PM   #7
HOGDADDY
HOGDADDY's Avatar
Originally Posted by GMC Guy View Post
ok so...
3. re-gear to 3.73
You do not need to modify the crossmember at all just move it back a scosh and you can use 2 original holes just have drill 2 more new holes.
The drive shaft does not have to be shortened or lengthened for that matter it is a direct swap.
Get a TV cable and correct geometry corrector for your carb is all.
While your at it grab a late model locking dipstick out of a 97 Silverado if needed.
The stock trans lines will also work but be sure and remove both lines from radiator and connect them up at the trans first then tweak em to match at the radiator.
HOGDADDY is offline   Reply With Quote
Old 03-03-2010, 11:46 PM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Hogdaddy is right on track ! you can get a TV cable corection bracket from Jeg's or Summit ( bout $30.00 I believe) I bought a used 700R4 a while back and had it rebuilt for bout $600.00, my brother had his rebiult and they charged him $1400.00, so it vary's how how much. I recently got one from a Pull-a-Part out CFC '91 Suburban for just over a $100.00 . I am confadent bout this CFC tran's see'ns that it come from a trade in, not a junk car ! go'n froma long tail shaft T350 it is practicly a bolt in swap, mabey tweek the cross member hole's .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-04-2010, 05:21 AM   #9
GMC Guy
GMC Guy's Avatar
thanks for the replies.
so when lookng for a used 700r4, what do i look for specifically?
what years will fit a 79 shortbed 2wd?
price?
i found this one, i don't know much about it though...
http://sacramento.craigslist.org/pts/1625428021.html
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-04-2010, 12:53 PM   #10
HotRod73
HotRod73's Avatar
Didn't know it was this simple... I figured a lot of modification was needed but this all seems right... going to start lookin for a 700r for my 73 c20!
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 03-04-2010, 03:03 PM   #11
jklonowski
jklonowski's Avatar
make sure you get a 89-92 700r4 for the updated pump they work a lot better and have a little better internals if you are going to hook it up to much power like me. cost me 50 dollars for a 91 core then 1300 for the rebuild. that came with all new red alto clutches updated sun shell heavy duty sprad etc. alltogether i spent around 1500. i bought a carb adapter kit the the guy who rebuilt it told me i didn't need one. i have a have a edlebrock 600. good luck
jklonowski is offline   Reply With Quote
Old 03-04-2010, 04:05 PM   #12
GMC Guy
GMC Guy's Avatar
found this company, and watched some youtube videos on them. looks like a solid tranny kit. ideas?
http://racetransmissions.com/store/p...roducts_id/309
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 03-05-2010, 12:43 AM   #13
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
i did a conversion on my caprice, very simple, best thing to do is buy new. I paid $2500 shipped for a 700r4, with a converter with the balloning plate and the tranny is built to hold 850hp. Go to eatmyshift.com this company (monster transmissions) is where i got mine. Give them a call and they will answer all of your questions.
staggerd86c-10 is offline   Reply With Quote
Old 03-05-2010, 08:43 AM   #14
silvereagle07
silvereagle07's Avatar
Try http://www.bowtieoverdrives.com/index.shtml or http://www.gearstar.net/transmissions/gm/700R4/. These are just a few I have looked at.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
