Old 03-03-2010, 07:38 PM   #1
jyaughn
jyaughn's Avatar
lowering the front of a 62.
so i have the torsion bars twisted all the way down and it still isnt low enough. what else can i do to get it lower?
jyaughn is offline   Reply With Quote
Old 03-03-2010, 08:28 PM   #2
72bigred
Re: lowering the front of a 62.
Drop spindles.. Some say you can put a longer bolt in the torsion bars but that bolt will end up scraping the ground. I have also read pulling out the torsion bar and re inserting it a half turn will get you a little lower but I have not tried that nor can confirm it. Drop spindles of 2.5 and with torsion adjustment its fine for me. If you want to slam it then you should swop out the front crossmember to a later chevy truck.
Reid
72bigred is offline   Reply With Quote
Old 03-03-2010, 09:31 PM   #3
jyaughn
jyaughn's Avatar
thanks for the help. i might swap the front stuff to a later model 60s setup with the springs up front. what all would i need to do this swap?
Old 03-03-2010, 11:41 PM   #4
60apache
60apache's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=366850
60apache is offline   Reply With Quote
Old 03-04-2010, 08:07 PM   #5
jyaughn
jyaughn's Avatar
seems like it would be alot of work
Old 03-04-2010, 09:44 PM   #6
62 Bowtie
62 Bowtie's Avatar
No matter what theres gonna be some work involved. I put the 2&1/2 dropped spindles 6 lug discs. In hind sight wish I would have swapped front crossmembers mainly due to exaust clearance issue and those dumb bolts that hang from the torsion bars.
62 Bowtie is offline   Reply With Quote
Old 03-05-2010, 12:48 AM   #7
**grumpy**
**grumpy**'s Avatar
Yeah, the bolts are the worst part.
Look at this pic of my old 60. You can clearly see the bolts hanging really close to the ground under the cab.
Thats with torsions turned as far as can go, bumpstops totally removed, and Toxic Shocks.
It rode really pretty decent, but I drug those bolts constantly....and sometimes if they caught just right on a pothole or speedbump, it was semi-violent...
Road Hounds
**grumpy** is offline   Reply With Quote
Old 03-05-2010, 06:51 AM   #8
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: lowering the front of a 62.
Mustang II IFS Clip!
That's what I did! And I dropped it more!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
Last edited by 1Bad62Pro/Street; 03-05-2010 at 06:56 AM. Reason: http://public.bay.livefilestore.com/y1p6PO8bDrId5gmsSwjRMZAyLZkajCfdcK91JsrAvqzsko0aQkLUi8IiJ3P83yfnvLVerSM7UajYAuCbPVFzcUERQ
1Bad62Pro/Street is offline   Reply With Quote
Old 03-05-2010, 08:37 AM   #9
scotts62
One day...
scotts62's Avatar
I swapped mine out with a 74 chevy cross member, with 2.5 drop spindles and air bags, it gets low enough
Scott
93 crew cab build
Project 62
Old 03-05-2010, 10:17 AM   #10
jyaughn
jyaughn's Avatar
could i swap it out to a 63 cross member and get everything from it?
