Old 03-03-2010, 09:28 PM   #1
ed2552
ed2552's Avatar
C20 Disc Brake Spindles, what years work?
Ok, so I'm on the hunt for some disc brake spindles for our 67 C20. What years will fit? I'm ok with changing ball joints and tie-rod ends, as they need to be replaced. Local yard has 74 spindles, will they work, or will only 71-72's work?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-03-2010, 10:19 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: C20 Disc Brake Spindles, what years work?
The 74 spindles will work just fine.
Get the steering linkage from tie rod to tie rod including the center link while you're there. With your new (74 year application) balljoints plus those parts you will be set.
Old 03-03-2010, 10:34 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
reman'd calipers are dirt cheap... cheap enough to not even bother running the old ones. If the rotors are real thick anf not pitted with rust, I'd run them over the new replacement ones.
Old 03-04-2010, 08:27 PM   #4
57larry
the Lman knows
57larry is offline   Reply With Quote
Old 03-05-2010, 09:30 AM   #5
ed2552
ed2552's Avatar
Thanks Guys!
TX: What's better about the steering shafts? Or is it to just get the proper tie-rod ends? I'm assuming 74 balljoints will fit in the 67 control arms?
