03-04-2010, 12:48 AM | #1 |
5 lug rear
for all of you that have converted your front end to disc brakes with 5 lug what are the options on the rear to get a 5 lug pattern?
03-04-2010, 01:18 AM | #2 |
60-66 Nut
Re: 5 lug rear
The '71-'72 rear ends are a bolt on for the coil spring suspensions in the '63-'70 trucks. Yours being a '60 I believe you will have to relocate the trailing arm mounts. I could be wrong though. You can use the '73-'87 10 and 12 bolts as well. Those are a little easier to find and if you do indeed need to relocate the mounts, it wouldn't make any difference which one you get. Either oine you get will be 1 1/2" wider than your current rear end (3/4" per side) You will also need to transfer your panhard bar mount to the new rear end.
03-04-2010, 02:46 AM | #3 |
Re: 5 lug rear
Yep The Captain is correct. You'll need to relocate your trailing arm pads for a newer rear end (anything after '62) or have your axles re-drilled, the hub pilot turned down, lugs changed to 1/2in to match fronts(this cost around 175.00) and new 5 lug 2 inch drums. This way your axle width doesn't change.
'77 GMC SWB '66 SNB (Project) Battle Ground, WA |
03-04-2010, 02:15 PM | #4 |
Re: 5 lug rear
The later rears are a little wider; another option is aftermarket 5-lug axles - I got a deal on some used ones on the parts side of this site (I think ECE sells them, a little pricey new but as opposed to swapping the entire rear - ?)
03-04-2010, 03:20 PM | #5 |
Senior Enthusiast
Re: 5 lug rear
I did what chevytrucknut explained - had the axles redrilled, 1/2" studs, turned down the hub and used the later finned brake drums. Was a bit spendy but a simple R&R compared to rewelding new mounts, and dealing with the width issues.
03-05-2010, 11:13 PM | #6 |
Re: 5 lug rear
what do you mean by hub turned down?
03-06-2010, 02:31 AM | #7 | |
fan of "Butters" Stotch
Re: 5 lug rear
I believe he means turning down the part in the very center that sticks through the drum
Also, another option is Early Classic axles http://www.earlyclassic.com/catalog.aspx prob the easiest, but not the cheapest Quote:
I currently have 6 lug axles as well, but may be getting back the wheels off my old car; 5 lug, 4 1/2 or 4 3/4 pattern Here's a pic
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again |
03-06-2010, 09:07 PM | #8 |
Re: 5 lug rear
Don't know why I didn't think of this before
http://www.moserengineering.com/ or http://www.moserengineering.com/moser/shop-services/
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again Last edited by tapeworm; 03-06-2010 at 09:07 PM. |
03-07-2010, 01:00 PM | #9 |
Re: 5 lug rear
If you get your 60-62 axles repatterned you need to bear in mind the very limited gear ratio selection. IMO the best thing to do would be to move the pads in on a 63-69 diff and have those axles redrilled if you need the narrower track , or just repad the 73- 80 12 bolt . personally i would just get a set of 6 bolt hubs and rotors for the front
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
03-09-2010, 10:42 PM | #10 |
Re: 5 lug rear
has anyone ever put an 80's model rear end in?
03-10-2010, 12:20 AM | #11 |
100% gearhead
Re: 5 lug rear
I am a bit confused about those of you who are talking about relocating the mounting pads on the later rears. I have swapped numerous '63-'72 (mostly '68-'72 as they are more plentiful) into early '60's trucks without any issues at all except for the panhard.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
03-10-2010, 01:15 AM | #12 |
Senior Enthusiast
Re: 5 lug rear
Just confirming - yes it means turning down the end of the axle hub where the center brake drum registration hole fits over it. I don't remember the dimensions, but the 6 lug brake drum center hole is much larger than the center hole in the later 5 lug drum. The axle end needs to be trimmed on a lathe to allow the later drum to seat flush.
Just a note - if you can find one in a wrecking yard, a 60-62 GMC 1/2 ton has the coil spring rear suspension and comes stock with a Dana 44 rear axle. Gear sets are plentiful for the Dana 44, which is why I decided to redrill mine instead of replacing the rear end. |
03-10-2010, 02:46 AM | #13 | |
Re: 5 lug rear
Next time you are near a stock 60-62 rear coil spring axle, measure the distance between trailing arm mounting pads. You'll find that the 63-66 axle pads are closer together like 3 to 4 inches. If you were able to squeeze a set of trailing arms together and mount the later rear ends, not only will the panhard bar be a problem but the coils would not be parallel and you'll smash the trailing arm bushings.The trailing arms wouldn't be able to freely travel and just be stuck and/or squeek really bad. I learned this the hard way after tring to install a '65 rear under a '62 I had. I had a heck of a time getting the u-bolts to go through and I had to use a ratchet strap to get the arms together. Once I did I drove it around the block and not only was it a very noisy and stiff ride,but the rear had come up due to dips in the road or curbs. The back of the truck was stuck all the way up as far as the shocks would let it travel. Taking the thing apart was also an adventure. I have found more than one 60-62 in wrecking yards with a later axle bolted in with just the U-bolts with no pads touching the trailing arms at all. Scary.
03-10-2010, 07:55 AM | #14 |
Re: 5 lug rear
I don't think they will work real well. I believe they are a two or three inches wider
03-10-2010, 09:51 PM | #15 |
Re: 5 lug rear
I thought 1.5" please confirm
03-10-2010, 10:40 PM | #16 |
Re: 5 lug rear
If by 80 s you mean up to'87 it should be 1.5 inches wider but would prolly be a 10 bolt after 88 Ive never measured one
03-10-2010, 10:51 PM | #17 |
Re: 5 lug rear
Yup, it is 1.5" wider between the pre-70 and the 70-87
The 88-up are more like three inches Here is a 72 axle going in a 66 http://67-72chevytrucks.com/vboard/s...d.php?t=313491 Similar, just will need to relocate the mounting pads as the others mentioned
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again Last edited by tapeworm; 03-10-2010 at 10:57 PM. |
