03-04-2010, 02:38 AM | #1 |
Looking for HD rear drum brake p/n's
Anyone have a source for the part numbers breakdown on rear 1/2 ton HD brakes (73-80 Suburban)? They would be the JB6 (?) 11.15 x2.75".
03-04-2010, 03:03 PM | #2 |
On the fast track to nowhere..
Re: Looking for HD rear drum brake p/n's
All I have is a generic illustration but I can get you part #s if you can tell me what all you need.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
03-04-2010, 05:17 PM | #3 |
I'm just glad to be here!
Here is what I found for a 1977 Chevrolet Suburban, 11.15 x 2.75 brakes...
Drum Brake Hardware: Raybestos H7046 Dorman HW7046 Adjustiong Screw Assembly Raybestos H1544 left Dorman HW1544 left Raybestos H1545 right Dorman HW1545 right Drum Raybestos 2083R or 2083 Wheel Cylinder Raybestos WC37048 Brake Shoes Wagner PAB450R Raybestos 450PG Spring Hold Down Top Cup (part of the hardware kit) Raybestos H1133K Spring Hold Down Bottom Cup (part of the hardware kit) Raybestos H1129 I do not believe that this is ALL the parts in the drawing BACKYARD88 posted. I think that it is only the replacement/rebuild parts. Items 7, 12, 14, 15 and 39 (form the drawing), I cannot find part numbers for them...I did not look real hard...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-04-2010, 05:52 PM | #4 |
I surfed for hours last night looking for a breakdown like that.... I'm looking for a GM (or alternate) p/n's for part 29 & 4 (for the bore size) in that index.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-04-2010 at 05:53 PM. |
03-04-2010, 06:45 PM | #5 |
Best I can tell the wheel cylinder has a 15/16" bore.
03-04-2010, 07:28 PM | #6 |
That's what I came up with & was trying to confirm. Now the backing plates....
03-05-2010, 10:38 AM | #7 |
LH plate GM# 14068965
RH plate GM# 14068966 I couldn't find alternate part numbers, and I couldn't find the GM anywhere.
03-05-2010, 10:40 AM | #8 |
Figures.... Nothing is easy to find these days. Thanks for the p/n's. If I might inquire, where did you source them from?
03-07-2010, 04:22 PM | #9 |
I'm a parts guy at a GM dealer. My catalog(computer) goes back to 73 and I have a paper catalog for 47-72. If there's anything I can ever help you find just let me know and I'll give it my best shot.
03-07-2010, 06:53 PM | #10 | |
I'm stashing your contact info .
