Engine Swap
I have a 63 C10 which came with a inline six. I have a 454 to swap in. Right now the truck is down to the bare frame, cab is off. My question is Can the new motor mounts go in the same location or moved somewhat further forward?? Engine came after cab was off. Any help is greatly appreciated
![]() Join Date: Sep 2006
Re: Engine Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=259536 Here is my thread. There are several more that cover alot. Anyone got one, just pass it along.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Engine Swap
Which motor mounts are you going to use? If you plan on running taller than stock valve covers, you'll want to move it forward from the stock location. Otherwise you'll need to modify the firewall. I moved mine forward about 2" and built some custom motor mount brackets. There are a few members here that have big blocks in their trucks or Suburbans. You might check out Protrash64's thread in the projects and builds section. He is in the process of installing a big block in his '64 Suburban.
Re: Engine Swap
Thanks for the info
Re: Engine Swap
I did the very same swap. Put a 454 in a 63' with everything blown apart. I did use the 73-87 motor mounts. I did have to notch the insides of the frame rails to make them work, as well as drill new holes into the crossmember to get everything to line up. Wasn't a big deal. I am running a big cap HEI distributer, short or standard size valve covers, and headman headers for an 73-87 chevy 1/2 ton truck, and everything lined right up with out any interference. I still have clearance to adjust distributer, and pull valve covers off with out a problem. I will try to get some pictures posted. I am also running a GM serpentine set-up that I got through Summit, best deal ever, everything fits nicely, with just enough room for electric fan set-up.
James |
Re: Engine Swap
Re: Engine Swap
Cant wait to hear mine roar.
Re: Engine Swap
What aspect of Big block's make them sound like rocks in a coffee can? I love it.
'64 Corvair Ragtop '66 C10 Stepside "The oxen may be slow, but the Earth is patient" |
#9 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
![]() Ooooh Yeeeeeah! I dig it, Brother! ![]() I have to ask about that Rat Motor..... What kinda bump stick you have in her. What's your specs on that motor.... She's snortin, spittin and growlin something fierce!
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
Re: Engine Swap
How low do those headers go below the frame?
Re: Engine Swap
I have not had it on a dyno yet. Estimated at 400 hp 500 tq. stock bore, balanced crank, comp cam with .298 intake and .301 exhaust, air gap intake, 750cfm carb, hedman headers that hang four inches below the frame
#12 | |
Re: Engine Swap
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Tags |
454 engine swap 63 |
