Old 03-04-2010, 02:27 PM   #1
robbiedenton
any advice on 62 crossmember swaps
Got a 62 stepper and I want to find out what crossmembers can I swap and rear ends? I would also like to know how to get this truck to lay frame without porterbuilthotrods!!!
robbiedenton is offline   Reply With Quote
Old 03-04-2010, 03:02 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: any advice on 62 crossmember swaps
My '62 has a front crossmember (subframe)from a '73. Also, it has a '72 rear end...
As for laying frame, from what I see and read on here, a dropmember is the best way to go.
jc62
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-04-2010, 03:08 PM   #3
robbiedenton
Thankx 4 the info, did u do the power steering conv to??
Old 03-04-2010, 03:11 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Here's a thread that explains the details of the later crossmember swap, but doesn't address the lowering issue.
http://67-72chevytrucks.com/vboard/s...d.php?t=366850
Old 03-04-2010, 03:16 PM   #5
robbiedenton
Thank you
Old 03-04-2010, 03:27 PM   #6
robbiedenton
Cool Re: any advice on 62 crossmember swaps
That's what I call a perfect thread!!! Thanks again for the post.
Old 03-04-2010, 04:17 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
You will have to use some old school methods to do it, but it's possible. If you can fabricate, then you are in business; if not you better start saving some $$$.
Dropped spindles get you a couple inches. You can consider a bodydrop(channeling) and Z'ing the frame. Also the stock front x-member can be cut to sit lower in the frame; same thing P/B's stuff does. Stepped a-arms are another method.
Some combo of these things will get you where you want to go, but all of them open up endless cans of worms as you can probably imagine.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-04-2010, 05:17 PM   #8
robbiedenton
Thank u, do u have any info on what would be the best? I have all tools and can make miricles happen but I don't want to do anything unnecessary. Do u no anything about z'ing the frame, is that my best bet?
Old 03-04-2010, 05:38 PM   #9
robbiedenton
Any z'd info anybody????????
Old 03-06-2010, 01:38 AM   #10
low900rr
Its porterbuilt streetrods!!! You said you bagged one truck already and have the tools to make miracles happen. Now go get to work!!! Should be a no brainer for you if youve done one already.
My builds
69 stepside.......2wd to 4wd
http://67-72chevytrucks.com/vboard/s...d.php?t=330675
and the new 66
http://67-72chevytrucks.com/vboard/s...d.php?t=302321
low900rr is offline   Reply With Quote
