03-04-2010, 04:50 PM | #1 |
67chevy250l6shutter
i recently purchased a 67 chevy c-10 pick-up it has the 250 4.1lt l6 everything seems to be original (not restored) just original equipment i noticed after a couple days it would idle extremely high tinkered with it and figured out it was timing i fixed that but now it seems to wanna shutter on take off could it be just a bad clutch and flywheel or something worse any thoughts would be greatly appreciated..and yes i am a newbie so i apologize if this question is obvious or i left something out.
" Seriously...Who Farted? " Last edited by MrOrange67Chevy; 03-04-2010 at 04:52 PM. |
03-04-2010, 05:05 PM | #2 |
Re: 67chevy250l6shutter
broken motor mount maybe or trans mounts on the bellhousing, worn clutch, could be something else
1967custom |
03-04-2010, 05:38 PM | #3 |
its all about the +6 inches
could be a misfire too, when an engine gets put under a load (taking off) it is more likely to misfire.
The motor mounts and clutch chatter are other good ideas, but i would start with new plugs wires cap/rotor and new points. |
03-04-2010, 07:27 PM | #4 |
I am a Referee of life.
Adding to Andy's suggestion check the vac advance actuator in the distributor.I had a bad one with the same symptoms.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-04-2010, 10:08 PM | #5 |
how do i check vac advance..and the distributor is the one thing they did change..to a hei dizzy also from another post i read i noticed they didn't change the resistor wire to a normal 12v wire and the plugs and wires and fuel pump/fuel filter are first things i changed.
" Seriously...Who Farted? " |
03-05-2010, 12:32 AM | #6 |
I would look at the flywheel& clutch for the shutter you speak of maybe a hotspot on the flywheel just my .02 good luck, Pat
