03-04-2010, 06:57 PM | #1 |
how can i convert a 72 to disc
im in the process of bagging my truck and i dont think it sits low enough in the front so i need spindles but my truck has drums
how can i convert my truck to disc w/o having to buy the $900 kit that doesnt even redo the rest of the suspension i already could use new tie rods and ball joints, is there a way to use newer model stuff w/o costing so much, $900 would be fine if it replaces my whole suspension up front w/ new stuff i read about the 66 conversion how much of this stuff applys to my truck thanks |
03-04-2010, 07:11 PM | #2 |
Re: how can i convert a 72 to disc
Your 72 already has disc s up front.....
http://community.webshots.com/user/hotrodhorn |
03-04-2010, 07:18 PM | #3 |
not mine, i have drums and had springs all the way around and power nothing, it was the lowest model of a fullsize i believe
03-04-2010, 07:33 PM | #4 | |
To get discs up front w/o spending for a kit, hit your local wrecking yard (or search Craigslist for your area) for a 71-80 GM truck getting parted out. The parts will easily swap over to your current frame.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-04-2010 at 07:33 PM. |
