Old 03-04-2010, 07:11 PM   #1
cparman
sharp as a marble
Three on the help
Well this old man stepped on his tongue today. I have a 69 c-10 in my shop, and it had a cheapo floor shifter in it that was worn out. I told the owner I had everything he needed to make it a TOT. Well, I almost had everything. My 69 was a TOT, but mine is a v-8, his is a six. The frame engine mounts on mine are in the front two holes, and his are in the rear two holes. I have what I think is the correct rods that run from the column to the trans, but IF all of you 6 cyl guys would help a brother out with a picture or two My morning might go better
I would also be much appreciative of this
Chip
cparman is offline   Reply With Quote
Old 03-04-2010, 08:36 PM   #2
JimKshortstep4x4
Re: Three on the help
Isn't the transmission in the same location for both applications?
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-04-2010, 08:43 PM   #3
cparman
sharp as a marble
I know that the engine mounts are different. IF the trans was 4" or so forward I would be done by now. I am assuming that the shift linkage is a bit longer. I have a good friend that has a small junkyard, and went to him this afternoon. he gave me a set of linage from what he says was a 6cyl TOT. They are a bit longer, and hopefully will work.
This thinking thing is giving me a headache!
Old 03-04-2010, 08:44 PM   #4
jsmithbm
jsmithbm's Avatar
whatca want a pic of?
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 03-04-2010, 08:45 PM   #5
jsmithbm
jsmithbm's Avatar
there is a u shaped bracket that connects to the block for the z bar, do you have the z bar?
Learning as I go!
Old 03-04-2010, 08:57 PM   #6
jsmithbm
jsmithbm's Avatar
here are the two pics i had, hope it helps.
Learning as I go!
Old 03-04-2010, 10:29 PM   #7
pritch
pritch's Avatar
I think the bracket on the frame is different between the 6's and 8's. I have some pics, but I need to find them. I'll go look.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 03-04-2010, 10:39 PM   #8
pritch
pritch's Avatar
This is the set-up for a six:
'68 Panel
'68 C-10
Ol' Green
Old 03-05-2010, 08:22 AM   #9
cparman
sharp as a marble
thanks for all of the help, but I guess I did not ask the correct question. Are the shift rods longer for a 6cyl ? the two rods that run from the column to the trans. My friend gave me a set that look similar, but are longer. Which is what I think I need.
Old 03-05-2010, 06:19 PM   #10
cparman
sharp as a marble
the two longer **** rods were the cure. A new day, a better attitude, and wa la! The three on the tree lives another day!
