Old 03-04-2010, 09:50 PM   #1
dean jendro
Old and crusty
dean jendro's Avatar
Rear mount gas tank questions
I want to put a tank in the back and eliminate the in cab tank. I have a 64 short stepside and I don't want the filler in the bed. Has anyone out there done any fillers that come out the side or rear and do you have pics of the finished look. Thanks.
dean jendro is offline   Reply With Quote
Old 03-04-2010, 10:31 PM   #2
TR65
TR65's Avatar
Re: Rear mount gas tank questions
Hey Dean,
There are a million posts out there on this.
Mine is on the inside bed side. If you want more pics of this method let me know.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 03-04-2010, 11:51 PM   #3
Northern lights
On the back of the fender (stepside) doesn't look too offensive if done right. My '64 short fleet used to have the filler behind the tail-light. Sounds like a good idea but it sucked.
Northern lights is offline   Reply With Quote
Old 03-05-2010, 01:02 AM   #4
BMSJaX
BMSJaX's Avatar
I am currently gathering parts to move the tank. I have decided to go with a Jeep fuel fill. they are pretty cheap and easy to come buy on ebay. Paid $20 with shipping for mine. Dont have any installed photos yet as I am still gathering parts for the conversion sorry.
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 03-05-2010, 08:45 AM   #5
lakeroadster
More details in my build thread..... post #8
Gas Filler Pipe: Bob Drake Reproductions P/N 78-9034-B, 1937 Car,
Locking Gas Cap: Bob Drake Reproductions P/N01A-18416-B, 1932-50 Pickup
Plus some GTAW welding and Home Depot Parts.........
lakeroadster is offline   Reply With Quote
Old 03-05-2010, 09:28 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I originally mounted a 1967 series C10 filler neck on the driver side bed wall, under the rear fender near the top. At the time I was going to be running a hard cover on the bed, so I ran a sealed gas cap and mounted the roll over/vent valve in this location. A local muffler shop bent up a piece of exhaust tubing to connect the neck to the custom Rock Valley tank.
The setup worked perfectly - except - for one design flaw. When I designed the tank, I had them fabricate an inlet elbow on top of the tank (circled in photo). The radius of the turn was too short, and unless the tank was filled at dead slow, gas would kick back, shutting off the pump nozzle. It took forever to fill the 33 gallon tank. There was plenty of room for a longer inlet, I just hadn’t considered the short radius neck a potential problem.
To retain the side fill arrangement, I needed to either replace the elbow on the tank with a baloney slice opening on top, or relocate the inlet to the side of the tank. Either repair would have allowed fuel to freely enter. By the time I discovered the problem the truck was my daily driver and I lived 40 miles from town, so I couldn’t afford to be without it long enough to pull the tank and have a radiator shop modify the opening. Instead I pulled the tank, filled it with water, cut a new hole and installed an aircraft gas cap directly through the floor. The tank was dried out, refilled and reinstalled in time for work on Monday.
I was really disappointed it didn’t work out, since it was very convenient to access and would have worked fine if the tank opening was modified. I’ve never seen anyone else install the filler in this location, which is a very clean solution and avoids the problems associated with a floor fill.
Old 03-05-2010, 10:31 AM   #7
dean jendro
Old and crusty
Thanks a lot for the ideas. I will review all the post threads on gas tank installations and figure it out. My box is in pieces and I'm almost down to bare frame so now's the time to do it right.
Dean
Old 05-27-2010, 04:04 PM   #8
Russ65C10
Russ65C10's Avatar
Hey has anyone used the jeep cj fuel tank for the rear bed install on a short bed?
The dimentions seem to be about as good as you could get....
Capacity: 15 Gallons/57 Liters
Dimensions: 25-1/4 X 18-1/4 X 10-7/8 inches
Short filler pipe - 1 inches
Small gauge hole - 2 inches inside diameter
Long vent pipe - 6 inches
Russ65C10 is offline   Reply With Quote
Old 05-28-2010, 08:45 AM   #9
lakeroadster
Where would you put it, on the fender? Seems like that would look pretty gnarly, and not the good gnarly.
Old 05-28-2010, 12:27 PM   #10
Russ65C10
Russ65C10's Avatar
I talking about using the Jeep fuel tank instead of a Blazer tank. It would go under the bed behind the axle where you would normally mount the Blazer tank.
Our short beds don't have a lot of room for a big tank under the bed. I'm trying to find something that will fit, is inexpensive and doesn't take a bunch of modificaitons to install.
Old 05-28-2010, 01:48 PM   #11
raycow
I use my truck as a truck, so I don't really want the filler inside the bed. My plan is to put the filler inside the stake pocket, fabbing an oversize "pocket" if necessary. Before I get myself into trouble, has anyone actually done this, or at least seen one like this?
Ray
raycow is offline   Reply With Quote
Old 05-28-2010, 03:35 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
Haven't seen it done, but If you choose to do this, make sure you minimize the number of sharp turns in the fill pipe. Refer to my post #6 above for the problems I ran into. I really liked my solution, but after a lot of work designing and installing, it failed in actual use.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
