Old 03-05-2010, 12:49 AM   #1
jj_62607
jj_62607's Avatar
inline 6 to 350
1974 c10 just swapped out the inline for a 350 with hei do i need to change wiring harness
jj_62607 is offline   Reply With Quote
Old 03-05-2010, 08:10 AM   #2
SSC's76
No No
SSC's76's Avatar
Re: inline 6 to 350
No you can shorten it up a bit but no need to swap. When the wife and I swapped in the v8 into her apollo I spent a few extra hours shortening and re routing the harness to make it look more presentable. Granted I did end up fixing years of previous owner hack jobs and quick fixes to the wire system but would it have not been needed I would have left most of it alone.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-05-2010, 08:53 PM   #3
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
Re: inline 6 to 350
you only need to add a power wire for the HEI, the coil power feed from the points setup is not enough juice. It will run it but not the way it should
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
