Old 03-05-2010, 01:57 AM   #1
Broken_down?
Sad day...
Well I just happend to look outside today from the kitchen window and my heart sank and I got that upset feeling in my gut. The gutter looks to be rusting Is there anyway to fix this without haveing the gutters removed and rewelded back on? Is there anyway to stop this? I know for gas tanks you can put i think some pour 15 and it will remove rust and reseal. I realize the proper way to fix it to remove and fix, but I don't have the means to weld nor do I know how. Any temp fixes till I get the experience to do so or can afford to pay someone to do it??
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 03-05-2010, 03:05 AM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Sad day...
The caulking is old and cracked, and water has gotten underneath it. It doesn't look bad at all. A screwdriver to scrape it out, a wire wheel on a drill and/or sandpaper should clean it up, you can por 15 it and put new caulking/sealant in (others can chime in on what's best to use, I can't recall the name of the stuff... 3M something...?)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-05-2010, 03:12 AM   #3
dazza
dazza's Avatar
Re: Sad day...
I agree with Redneck, from the pics it doesn't look too deep or rusted through. Don't think you'll need to have any welding done.
Napa carries a seam sealer that I used on mine, worked great.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 03-05-2010, 12:52 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Sad day...
You should see mine. Yours looks dang near new compared to my '72. Most of the caulk/body sealer crud on mine is gone and the the cab seal is exposed. I need to chip/grind the rest out and reseal and then paint.
You just need to chip/grind the caulk/body sealer out of there and redo it. My local Napa auto parts has the correct body sealer. Not an easy or fun job... but it is doable.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-05-2010, 01:05 PM   #5
clos69
Its Topless Season!!!!
clos69's Avatar
Re: Sad day...
Dazza- is there a specific name brand. I am interested,thx
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 03-05-2010, 01:17 PM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Sad day...
I agree with what others have said. you can go to Napa ( they carry 3m products), or a local paint supply store. you will want self-leveling seam sealer for the top ( this will lay flat when cured), and heavy-bodied seam sealer (for vertical areas) as you start getting closer to the back (curved area above door) and down the remaining drip rail.
You could always drive by a body shop and ask if you removed the old sealer, and wire wheeled it , what would they charge to apply the seam-sealer
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-05-2010, 01:24 PM   #7
mrein3
mrein3's Avatar
Re: Sad day...
Jump in your truck and pull back the inner rubber windshield seal. If you don't see any rust or bubbles under the paint, you're good.
Simply do as others said. Remove, wire wheel, treat.
For areas that are surface rusted I like the acid etch available from DuPont and PPG instead of POR-15. The paint companies make an acid that is made to go under their primer and paint products. I've used it and have never yet had surface rust come back when properly treated.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 03-05-2010, 02:04 PM   #8
MAK191
Re: Sad day...
I think this is the correct one. http://www.autobodytoolmart.com/3m-a...7-p-10855.aspx but there are several brands available and some are high build.
MAK191 is offline   Reply With Quote
Old 03-05-2010, 02:06 PM   #9
MAK191
Re: Sad day...
forgot to ad if you use the specialty ones like 3m and SEM you need a special applicator gun
Old 03-05-2010, 03:17 PM   #10
GASoline71
GASoline71's Avatar
Re: Sad day...
I just got the Napa brand in a tube that works in a regular caulk gun. I also used some seam sealer in the areas around the bottom corners of the windshield where the cab comes together there as well. Another good spot to chip all the crud out and reseal. I think that is where a lot of water gets in over the years and rots out the kick panels, and floor.
Great trucks... but if you ask me, a poor design where the cab seams are. Then again, most trucks of that era (no matter the make or model) are put together that way.
Gary
Old 03-05-2010, 03:33 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Sad day...
I did just like they suggested then primed and rattle canned over it (since I can't do paint yet).Clean,then use a rust converter, then primer, then the sealer, and then prime again(It seems to let the paint stick to the sealer better) then rattle can it to seal the primer(primer will absorb water).
And I got lots more drip rail then you.It took two tubes to do the sides and I need to do above the rear doors if it ever warms up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-05-2010, 09:06 PM   #12
GASoline71
GASoline71's Avatar
Re: Sad day...
Here's some pix of mine... See... yours really isn't all that bad considering the age of these trucks.
Gary
Old 03-05-2010, 11:31 PM   #13
pat 70/71
pat 70/71's Avatar
Re: Sad day...
I re did mine. i ground & cleaned all the original caulking out of the drip rails & used mar- glass to fill in the seam & shaped it with my finger. works great its been six years / no problems so far. ( not a pro) prep/spray as usual. best of luck, Pat
pat 70/71 is offline   Reply With Quote
Old 03-06-2010, 09:18 PM   #14
Broken_down?
Re: Sad day...
Awesome news. We are moving into our new house in less than 30 days so will chip it off asap and real seal. Sad though I need the kick panels too. All in do time I am pickip my battles right now..lol
Thanks guys you all rock!!
Old 03-06-2010, 10:51 PM   #15
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Sad day...
Hey brokendown, I'm in oroville too. Guess I'll know who to pm when I need help! Cool to see someone else in the area, I've seen lots from sac and one from magalia, but none from O-town.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-06-2010, 11:07 PM   #16
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Sad day...
dude mines worse than all of you folks'!!!!
yeah yours looks great id try what these truck educated folks gotta say
John
1999 Toyota Tacoma 4x4
Old 03-08-2010, 02:11 AM   #17
Broken_down?
Re: Sad day...
LOL! There is never anyone one from our arear. I live in thermalito currently but will be moving right up next to kelly ridge in 24 days! Where you at in oroville? Any close pics of your rig? mine is currently on non-op due to needing a motor. Still looking to score a 327 runner in 67/72 era. Manyy 350's but wanna keep her stock. You gonna go to the feather fiesta days this year? Ever year they have this bad ass strecthed c20 that is orange.
later
