Old 03-05-2010, 02:36 PM   #1
CrazyJesster
CrazyJesster's Avatar
Drivetrain question
ok so i got an 82 swb as some of ya know
and my question is if i were to get like a 97 rearend the whole housing an all and replaced it with the one in my 82 whould i have to do any frabracating ? for brackets or should it all bolt up
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842
CrazyJesster is offline   Reply With Quote
Old 03-05-2010, 03:46 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Drivetrain question
You will have to move the spring perches and shock mounts. Not sure if the brake line is the same thread pitch or not.
--Josh
Old 03-05-2010, 08:28 PM   #3
CrazyJesster
thought about trying to find a wrecked one in the junkyard. and getting the entire rearend and using it. beein its alreay got posi track
an one of thease days i whould like to get an LS1 engine an build a 383 stroker
Old 03-07-2010, 05:25 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
You will have to do some cutting and welding. I put a 91 rear in mine. You existing rubber line should thread right into the splitter block on the newer rear end. It threaded right in on mine.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 03-07-2010, 08:38 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by CrazyJesster View Post
thought about trying to find a wrecked one in the junkyard. and getting the entire rearend and using it. beein its already got posi track....
Are you assuming that they all came with a posi-trac? if so, that is not correct. Just like the 73-87, the 88-98's could be ordered with a locking dif, but did not come "standard" with one.
Search your local Craigslist and find a 73-87 12 or 10 bolt with a posi. That will bolt right and "and" be the same width as what you have now.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-07-2010, 09:31 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Go for a Caddy or Lincoln rearend. Same 5X5 bolt pattern and disc brakes! The wider axel aligns the travel path with the wider front path on our trucks. Same work as adding a 88+ 1/2 ton rear. You have to move the perches and shock mounts.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-08-2010, 12:28 AM   #7
CrazyJesster
i think i may just get locker and put in the rearend thats in it. i think its a 10 or 12 one of the two for sure. and change the gears out as well the guy i bought the truck from. they put the 400 in it when the 350 blew up. and they pulled a race car with it they also changed the rearend. i thin it is a 12 bolt its been a while since ive looked at it. i do remeber the guy saying it has 4.11
but i know in my 97 z71 i had it was a posi and also in my 01 its posi
ive even thinkin about trying to locate a 5.3 and 4l60e an computer and do a swap. then an ls6 cam and some headwork and a tune
read an article in hotrod they did a tune some headwork and a ls6 cam in a 5.3
and it was about 450hp
im thinking 3.73 gears and maybe a detroit or something i dunno
Old 03-08-2010, 12:59 AM   #8
spinem
haha, ford guys...
what about u-joints??!!
spinem is offline   Reply With Quote
