03-05-2010, 05:25 PM | #1 |
wilwood d52 calipers
Just curious to see if any of you guys have used wilwood d52 calipers. they look really cool for one. The stock caliper is single piston, the wilwood is twin. Any feedback would be great. I ordered a set today. If nobody has used them, maybe I'll be the guinea pig.
http://www.wilwood.com/CaliperList.a...0Dual%20Piston
http://www.gulftruckinc.com |
03-06-2010, 08:40 PM | #2 |
Re: wilwood d52 calipers
talked to a tech guy from wilwood, he says hes getting some good feedback from people using these calipers. mine should be here tues.
[IMG][/IMG]
03-06-2010, 09:25 PM | #3 |
be sure and post results, i'm really curious if these just "bolt on"
1987 350 TBI lowered 5/7 |
03-06-2010, 09:27 PM | #4 |
Looks like a nice alternative to stock . Is the price for a pair or a single caliper?
Frank
Born and proudly residing in a Red State ! |
03-06-2010, 09:31 PM | #5 |
67-72 parts collector,…
$165 each from Jegs.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-06-2010 at 09:32 PM. |
03-06-2010, 09:32 PM | #6 |
Ive been trying to do tons of research. the best i can tell they bolt to stock spindles,use stock rotors and pads. The price is each, Sucks!!! I think their going to look killer though. especially with a rear kit also.
03-06-2010, 10:00 PM | #7 |
They make them for both the 1" front rotors and the 1.25" front rotors.
Make sure you get the correct caliper.
03-06-2010, 10:11 PM | #8 |
I think CPP was selling them for $300 per pair with braided lines. There are treads in the suspension forum.
I can still count my vehicles on two... wait three hands. |
03-06-2010, 10:12 PM | #9 |
yeah they do. I double checked my rotor width.
03-09-2010, 09:55 PM | #10 |
A lil teaser for you guys. just got them today. I havent had time to install yet but i just wanted to snap a couple of pics.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
03-09-2010, 10:13 PM | #11 |
[QUOTE]A lil teaser for you guys. just got them today. I havent had time to install yet but i just wanted to snap a couple of pics.[QUOTE]
looks killer man! i'm still curious though if there just "bolt right up" or not wheres cpp? anyways?
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 03-09-2010 at 10:33 PM. |
03-09-2010, 10:18 PM | #12 |
I found the cpp site but didnt find these calipers. as far as bolting right up, I hope so. all i know these things look way cooler in person. I wish they would have been a lil cheaper.
03-09-2010, 11:44 PM | #13 | |
[quote=bigarmzz;3850747][QUOTE]A lil teaser for you guys. just got them today. I havent had time to install yet but i just wanted to snap a couple of pics.
I have a set bolted to some Belltech 3" drop spindles. So does 69chevyshort.
03-10-2010, 02:26 AM | #14 |
It'd be alot cooler if you did
man I think those just might be the answer...
03-10-2010, 12:34 PM | #15 |
Squarebody Aficionado
will they work with those put together rear kits that guys get the parts off of other car to do the rear kit? anyone have a parts list of what need to do the rear like that? I might be able to get the parts new and instead of buying stock calipers just buy those the first time around.
03-10-2010, 01:15 PM | #16 |
03-10-2010, 10:38 PM | #17 |
they will bolt right up. but the factory brake lines wont. I am trying to come up with a way to use my factory lines. wilwood wants you to use a brake line kit. thats fine no problem. dont tell people they will bolt right up. they need to tell customers they need brake lines as well. I called them today and they told me this. would have been nice to know before hand.
I told the tech they dont just bolt up. he told me technically they do bolt up. I was not amused.
03-10-2010, 10:40 PM | #18 |
staggered, they will work with a blackbird kit, they use d52 style calipers.
03-13-2010, 11:40 PM | #19 |
I finally got the new calipers installed and are working. I will tell you how i did it and how i would recommend others to do this upgrade.
how i did it was i used the factory brake hose which takes a 10mm banjo bolt. the new wilwood caliper has 7/16 threads. i drilled out the factory brake hose block(very carefully) to accept a 7/16 banjo bolt. and it bolted up fine and bled well. seems to be working with no problems. I recommend buying new braided brakelines that will bolt right up without going through all of the crap that i did. well i hope this helps anyone that wants to do this upgrade. [IMG] [IMG][/IMG]
http://www.gulftruckinc.com Last edited by thehitchmaster; 03-16-2010 at 09:25 PM. |
03-14-2010, 05:28 AM | #20 |
That looks Sick!!!!! Is there a big difference in your braking??????
03-14-2010, 07:47 AM | #21 |
Will this caliper work on a 4 wheel drive truck?
03-14-2010, 12:33 PM | #22 |
Thanks man! As far as their performance. I just did the brakes on my truck before i ordered these calipers so my brakes were really good. I cant tell a huge difference. I was really just going for the look. As far as the 4x4 i am not familiar with them. Next will be a wilwood rear disc conversion to finish the look.
03-14-2010, 02:05 PM | #23 |
Happy to be here
Got more pics? I want to see the rest of the truck with the new wheels.
03-14-2010, 10:39 PM | #24 |
heres a couple. shes gettin there LOL. still needs a lot of work.
03-15-2010, 07:15 AM | #25 |
man, that is sharpppppppppppp
whats it lowered?
