Old 03-05-2010, 07:45 PM   #1
chevysbest92
chevysbest92's Avatar
rim question
hey guys, my PO put on a set of aluminum rims and i went to work on the brakes and put the rims back on, they wouldnt seat on the drums right, its like theyre are 2 little lugs comming out of the drum, are they suppose to be there? like placement studs? or did some guy break the old studs and just put these rims on to make it a rolling chasis? i checked the back of these rims and theres no extra holes for these mystery studs. and also, are the rims suppose to be huncentric or lugcentric? these rims dont sit on the hub, but the lugs are tapered to be lugcentric. just making sure so i dont have a wheel break off on the highway, thanks guys
I wouldnt have it any other way...CHEVROLET!
ALL throttle, NO bottle!!!
Theres NO replacement for displacement
Current Rides 2006 Silverado1966 Chevy c101972 Chevy Nova
Previous Rides
2003 Silverado
1992 Silverado
chevysbest92 is offline   Reply With Quote
Old 03-05-2010, 08:04 PM   #2
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Re: rim question
That seems a little wierd. I've had a set of drums that had like a 9/16 bolt head sticking out of it to hold the drom to the axle. I just took it off and the rims set right up against the drum. Is it something like that? Have any pics?
kalirodding is offline   Reply With Quote
Old 03-05-2010, 08:33 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Re: rim question
The only drums I've seen like that were on Buicks from the 50's and 60's. They didn't use lug nuts, they used lug bolts instead. The drum had a small tapered stud protruding to align the wheel. I believe early Mopars used this arrangement as well, which is why the early wheels all have 10 holes - 5 lug holes, and 5 smaller alignment holes in between the lug holes.
I remember when the chrome steel Astro slot wheels came out, there was a clear disclaimer that even the sheet metal tinnerman nuts that held the drum to the studs had to be removed, or the wheel would not seat correctly and damage the wheel. And of course I knew a guy that ignored the warning and mounted them anyway, bending the face and splitting the chrome.
I would be very cautious about driving it if they don't seat flush. As you guessed it was probably made into a rolling chassis, and if the wheels are put under a load without fitting correctly they will fail in service.
Old 03-06-2010, 06:52 AM   #4
blackedoutharley
Re: rim question
The wheels will be lug centric as hub centric really didn't come into widespread use until about the last 10-15 years on domestic autos.
Make sure you are using the correct type lug nut for the wheels with sufficient thread engagement. The biggest problem with our trucks is when installing aftermarket wheels that typically have thicker flanges there is not enough stud engagement for proper installation.
If your wheels require a standard conical seat lug nut I can't stress the importance of using "ET" style lug nuts enough.
See here for an example:
http://www.jegs.com/i/Billet-Special...7-bc510d253e51
(yes I know these are shown as 1/2" x 20 but they are available in 7/16" too)
If you are dealing with the front brakes are you referring to the rivets holding the drums to the hubs?
If so, I have always cut them off to make the drum free floating (like the rears) which makes general maintenance on the brakes much easier (cleaning and adjusting) without the need to pull the bearings.
Either way you should not have more than 6 studs per corner (assuming 1/2 ton).
Pictures would help greatly.
blackedoutharley is offline   Reply With Quote
Old 03-06-2010, 03:46 PM   #5
chevysbest92
Re: rim question
alright guys, thank you very much, ill get you pics hopefully tomorrow
Previous Rides
2003 Silverado
1992 Silverado
