Old 03-05-2010, 10:22 PM   #1
mcguire22
283 and powerglide
Alright, ive got a 64 chevy c10 with the stock 230 and three speed on the column. Heres the question, Im going to look at a rebuilt 283 and powerglide tomorrow. It is still in the guys impala. What am I going to need to swap this in. Motor mounts? custom drive shaft? anything else? If its going to be to much then I could always keep the stock trans in for now. It will be a weekend project since its my daily driver so im just trying to figure this out without getting myself in trouble. thanks guys
mcguire22 is offline   Reply With Quote
Old 03-06-2010, 08:23 AM   #2
mcguire22
Re: 283 and powerglide
come on now. I know somebody on this site knows the answer to this question. This website is full of infinite knowledge, so I know somebody can help me out.
Old 03-06-2010, 11:26 AM   #3
padresag
it is basically a bolt in if you use the 230 bellhousing and flywheel setup and maintain the 3 speed. same mounts. there are a few little things that you will require such as a ball stud for the z-bar. pilot bushing(there are 2 different sizes on od;about .025". unless you know which one(measure the hole in the crank,precisely, or get both and return the one that you don't require may be simpler for you. they are not expensive)
ron
padresag is offline   Reply With Quote
Old 03-06-2010, 12:49 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 283 and powerglide
You are going to need to match the powerglide with your 283 engine cam, and rear end.
What you use in the Truck to do will change the set up of things like the rear end, suspension, and transmission alot.
So when you do a engine/trans swap you have to build you truck around those combinations in order for it to be reliable.
I Had a 283 in mine before the swap.
Take measurements to determine weather you to lenghten or shorten your drive shaft.
Are you using the stock rear end?
Powerglide:
Length: 27 9/16”
To Mount: 20 9/16”
Gear Ratios: 1.76, 1.00
Nothing wrong with the powerglide.
There were two primary versions of the Powerglide.
The Powerglide transmission introduced in 1950 had a cast iron case and is known as the "Cast Iron Powerglide".
The "Cast Iron Powerglide" and was used until 1963, when it was revamped as "Aluminum Powerglide" where its case and several of its other parts were made of aluminum.
The Aluminum Powerglide was used from 1962 until it was replaced with the Turbo-Hydramatic series of transmission in the early 1970s. The Aluminum Powerglide is still used today as a racing transmission of choice by many racers mainly for the fact that it only shifts once, and for its extreme durability.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-06-2010, 01:54 PM   #5
padresag
if you are going to use the p/glide there is a lot more work and parts to locate, if there wasn't one there before. you will have to remove the crossmember under the bellhousing and locate or fab a rear trans crossmember as the is where the trans will mount. you will need all of the throttle linkages inc the frame brackets for such. shift linkage plus strg column unless you install a floor shift mechanism. depends on the length of the p/glide versus the 3spd if you have to alter your d/shaft. need to relocate emerg brake setup?
ron
Old 03-06-2010, 05:48 PM   #6
mcguire22
I knew somebody could help. Thanks guys. Maybe Ill see if he would just sell me the engine and ill live with the three for a while. So really all i need is a pilot bushing and a ball stub(napa I would think).
Old 03-06-2010, 08:48 PM   #7
padresag
just ask for the pilot bushing for a 283 p/glide crank. an older experienced counterperson will know or should know. the ones that depend upon the computer for their answers will not get it, so this why you ask for both. ball stud, you may have to go to a place like lmc. napa may have them but I doubt it. it threads into the block. your I6 one is welded into a bracket
you will need new hoses and little things like that,perhaps a change to the fuel line. you can run stock exhaust if you get the crossover pipe with the eng and should hook into he existing, unless you are going to modify it. not a difficult job
ron
Old 03-06-2010, 09:45 PM   #8
mcguire22
thanks padresag. You have been a big help. I am going to run long tube headers(i think the hedman ones) so the exhaust should be taken care of. The engine sounded great with no smoke. It does have a lunati cam which helps
Old 03-08-2010, 08:21 PM   #9
mcguire22
getting the motor but LMC doesnt have a clue what im talking about when I say the ball stud for the z bar. Does anybody know a part number or a different name for this part. Thanks
Old 03-08-2010, 08:53 PM   #10
astrochimp
I saw one in Classic Parts pt# 90-844 (? year engine size?)
http://www.classicparts.com/
They show a lot of clutch linkage parts
David
astrochimp is offline   Reply With Quote
Old 03-08-2010, 09:06 PM   #11
mcguire22
Its a 64 truck. Not sure what year the engine is. Its coming out of a impala. Can I order the bushings from that website too? Is that everthing other than fuel line and simple napa stuff? Man, I love this website. You guys are awesome. I think Ill do a write up with pictures to contribute to help. thanks guys
Old 03-08-2010, 09:07 PM   #12
padresag
if I read it right 32-6122 ball stud - eng LMC also here is the link to the page might as well get snap ring and felt to http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=74
ron
Old 03-08-2010, 09:08 PM   #13
mcguire22
Will 90-845 work?
Old 03-09-2010, 08:15 AM   #14
mcguire22
awesome. Got my headers ordered from summit and ordered my ball stud, clip, and felt from lmc. This might actually happen this weekend. Now I just need to find out about the pilot bushings. Does Lmc have those aswell? thanks
Old 03-09-2010, 11:30 AM   #15
padresag
as already stated your local jobber (napa or whoever) should have them and should have both sizes if you get the wrong one, you can go right back and get the other. otherwise you will wait for delivery and you said that you want to do the swap in a weekend, mind you , you can do the pilot bushing ahead of time
ron
Old 03-09-2010, 01:18 PM   #16
Russ65C10
Russ65C10's Avatar
My truck orginally had a 283 and a powerglide in it. Since you have a six and 3 speed manual you're going to need to change your engine mounts out. I beleive in your case your tranny is unsupported due to your engine being supported at the mid and rear (bellhousing). You will need a cross member for the back of the transimission. you'll also need new linkage and an auto colume unless you chose to go will something like a B&M floor shifter. If you're getting the complete engine/tranny then you should have all the kick-down and other related parts you'll need.
Also, I can't remember for sure but I think prior to 66 the six cyclinder trucks have a smaller radiator that you really should swap out for the larger one used for V8's.
Swapping in the 283 will definately make the truck a more enjoyable drive. Good Luck!
Russ65C10 is offline   Reply With Quote
Old 03-09-2010, 09:20 PM   #17
mcguire22
yeah, Im just going with the motor. I ordered everything and it should be a good weekend project. Ill be picking the motor up sat. morning about two hours away from me so time will be tight but it can be done. I have a shop so that will make life easier. Good call on the radiator, I will probably run the inline 6 for a while since it doesnt really get hot in the mountains of NC(mid 80's). I will switch it out in the next 6 months.
