It followed me home?
How many inches of rake for the perfect stance? Pictures always help
To you guys that think you have nailed the right stance how much lower is your front fenderwell than the rear?
Right now my Blazer sits about 1" lower in the rear than the front and I was hoping to fix it by putting a taller tire in the rear instead of having to redo the rear suspension. I'm thinking about 255-40-20 (28" tall) fronts and 295-45-20 (30.4"tall) rear, is that going to be enough rake? Can you guys post some pictures of your truck and measure the wheel well heights for me? Thanks
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Happy to be here
![]() Join Date: Mar 2000
Re: How many inches of rake for the perfect stance? Pictures always help
The rear wasn't all the way down in this pic. It should be about 1-2" lower but it gives you an idea of where it was headed. I thought the rake was looking good.
I think it looks just about perfect the way it is there but I like a lot of rake. That looks like about 2-3" or rake?
Squarebody Aficionado
this is a great question cause im having the same question i try to even out the stance of the truck buit it doesnt look right when its even unless its laying on the ground, if my suspension woes continue, i think im just going to bag the front so i can adjust the amount of rake on the fly.
I think it'll vary from truck to truck. Depending on how much your factory springs are already sagging.
'69 custom/camper '74 260z 302 chevy/tko500 swap in progrss '79 Malibu 355 all forged 4 speed car. '86 k5 blazer '06 Duramax |
#7 | |
Location: Where I come from, it's cornbread and chicken...
Chuck Last edited by Stitch; 03-07-2010 at 06:25 PM. |
I ran mine with around 8" of rake for years (measured at the body line above axle centers) and was happy, it looked like a cartoon ride but.
Eventually I lowered the rear 4" and with the tire combo I'm running it looks good in my opinion
And a couple more shots
OL BLUU
![]() Join Date: Mar 2004
Well I've been told that I have the perfect stance... but it depends on what you like. Mine measures 25 3/4" in front and 26 5/8" in the rear. Measuements were taken in the middle of each wheel...
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 03-12-2010 at 01:55 AM. |
#11 | |
6.0 powered square
I'd equal differences from top of rim to bottom of fender or a couple of inches higher in the rear a I think it was 24 3/4 front 27 1/2 rear
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-12-2010 at 09:19 AM. |
#13 |
Extended cab fanatic
The front tires are stock heighth, and the rears are one inch taller. I think there is a 2 inch rake, but seriously havent measured it. I will if anyone wants it tho.
If it has a motor, it has my attention. |
#14 |
It'd be alot cooler if you did
My favorite look on a static dropped truck always puts the fender lips about an inch above the wheel (20's front and back) with the tires tucking. Classic87 is a pretty good example.
If I had the bed on my truck I could get pics at what ever ride height you needed... Last edited by smashingchuck; 03-12-2010 at 02:03 PM. |
#15 |
CLASSIC87- How much did you lower yours and how? What wheel sizes are you using? That is a great stance, for sure! I'm going to blatantly copy you.
My 68 cougar restomod build:HERE |
