LED King
Reverse sounds and fun with the shifter knob
I have a new question - When I shift in to reverse, it makes a "metalic" noise for about a second. I can't really explain the noise, maybe I'll make a video on the borrowed digital camera to show you the noise.
I had tons of fun trying to get the automatic shifter knob off. Took me about an hour!!! ![]() My observations: It is a vinyl outer piece with a plastic inner. I took the vinyl part off and it had grease like stuff in it. WTF was that doing in there??? This thing is NOT held on my glue. The shaft has splines on the end of it which the knob locks on too. Not fun I tell ya. Next I installed the billet knob. Push on shaft, turn set screw, then sit back and admire. Question for all with auto trannys: on the underside of the truck where the shifter connects to the tranny, there is a plastic bearing by where the adjustment bolt is on the shaft that goes into the bracket on the frame. My plastic thinggies won't stay in. It makes it so the shifter can never be calibrated correctly!!! It makes the main shaft loose, is making metal rub on metal, and make it very noisy when I shift. How do these plastic bearings stay in??? Can anyone help me? I may just have to epoxy them.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 Last edited by apstguy; 02-02-2003 at 10:54 PM. |
I'm back with 2nd truck!
On the noise it might be a front pump going out. May be something else though. Is the shifting slow? How long does it take to go into gear?
Gear shift- Been there done that ![]() On the shifter you need a spring to compress the plastic bearing into the bracket where the rod from the shifter goes into.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Look at this.
pkbinplano
You da man Brandon !
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat |
LED King
On my tranny, I shift ::click:: ::clunk:: in gear. about 1/2 a second to shift. A friend of mine told me these old transmissions have a habit on dieing after changing the fluid. I guess I won't do that any time soon.
Thanks for the info guys! Went to the junk yard today and found the only 81-87 Chevy with a transmission still on it and grabbed the spring from it. I also got air duct hose for the right vent and the cheap metal pipe for the heat riser and brackets from an old oil cooler fron a Suburban. All for $2. Kick Ass!!! ![]()
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
MIght check the level and color of the fluid. May be time to change it and the filter.
LED King
I'm a little reluctant to do that since my friend says they usually die after you change the fluid. I can't afford that right now.
