Old 03-06-2010, 10:32 AM   #1
rhodog77
rhodog77's Avatar
1954 Cab with 47-53 front end
Hey guys,
quick question. does the front end and hood of a 47-53 ad truck mount up to 54-55 first series cab. If so, are there any issues or challenges that I should be aware of. I found a 54 cab but with no front sheetmetal but I have a mostly complete front end from a 1950. Any info, tips, tricks or potential problems would be great.
thanks
brian
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 03-06-2010, 12:12 PM   #2
mr48chev
mr48chev's Avatar
Re: 1954 Cab with 47-53 front end
I'm pretty sure it is a bolt on as long as the frame is Chevrolet. I've seen a couple around here that were daily drivers at the time just because the owners banged them up and couldn't find a 54 Nose.
The problems start when you want to use a Chev nose on a GMC frame or a GMC nose on a Chev frame as the front crossmembers are different and each has it's type specific core support.
Old 03-06-2010, 01:00 PM   #3
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
I agree, the nose and the front cross member on the frame should match or you'll have challenges. The differences can be overcome, but be aware you'll face them if you are mixing brands.
That same cross member issue will affect installation of a stock motor.
If we're talking half or 3/4-ton the bed needs to coordinate with the frame. If you have a frame earlier than '54 you can not use a '54 or later bed. There should be no problem using a '54 bed on an earlier frame. On a 1-ton it should make no difference.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 03-06-2010, 01:25 PM   #4
mr48chev
mr48chev's Avatar
And if you decide to use an S-10 or other frame because you don't have a frame it's all build mounts and fit anyhow.
Old 03-06-2010, 04:00 PM   #5
Dan Bowles
AD Addict
It should fit just fine. Its been done a hundred times. It just makes the best looking trucks in the world (54/55) not as pretty.
5150 has front fenders for sale for a 54/55 in TN if that'd help Keep America Beautiful!
(I have 3 54 Chevy's so I'm partial)
Dan Bowles is offline   Reply With Quote
Old 03-06-2010, 10:19 PM   #6
chevy49
chevy49's Avatar
brian it will work just fine.hood is the same, fenders changed only at corner of the grille and lower front.you need the cab!!!
chevy49 is offline   Reply With Quote
Old 03-06-2010, 10:30 PM   #7
Dan Bowles
AD Addict
Hood is NEARLY the same. The ornament location is different. We've got a '50/51 hood on my son's '54 right now.
Old 03-07-2010, 09:31 AM   #8
texas56
texas56's Avatar
I did it on mine and worked fine.
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
