Old 03-06-2010, 11:16 AM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
WTB: 6cyl Factory Tach Wiring Harness (open to 8 cyl wiring)
Looking for a factory wiring harness from a 6 cyl. tach setup, so if anything, I can determine the length of the leads needed. The 6 cyl. wiring harness will be longer than its similar 8 cyl. wiring harness due to the coil being half way up the right side of the motor vs. at the rear.
If someone can provide a measurement of the wiring that would even work.
Thanks in advance!
Nate
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-06-2010, 12:22 PM   #2
71swb4x4
71swb4x4's Avatar
Re: WTB: 6cyl Factory Tach Wiring Harness
I just took the V8 harness that I bought out to the dump truck; it has more than enough length for my 292.
The coil wire is about 67" from the end of the coil wire to the firewall plug.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-06-2010, 12:34 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow... that's exactly what I was looking for.
Thanks for the info! I contacted M&H Wiring (IIRC) and they were looking for some specs to build on.
No need to buy one unless someone has one laying around or if you have any pictures on how the wire was routed.
-Nate
Old 03-11-2010, 03:55 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
bttt... open to nice original 8cyl tach wiring as well.
-Nate
