Old 03-06-2010, 11:39 AM   #1
65Guy
65 frame question.
I bought my truck about 2 months ago and the truck has factory powersteering and 5 lug wheels all around. I know the trucks only came 6 lug. how do I tell if this is a later year frame and what year did chevy start factory powersteering and 5 lug patern.
65Guy is offline   Reply With Quote
Old 03-06-2010, 01:15 PM   #2
SCOTI
SCOTI's Avatar
Re: 65 frame question.
Dead give-away should be the front frame horns. 6x-66 front frame horns are physically shaped different vs. post-66 trucks that came w/pwr steering & 5-lugs. Factory 5-lug set-ups started in 71.
5-lug (disc) set-ups & power steering are easy to swap to a 65 6-lug drum brake equipped frame.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-06-2010, 02:26 PM   #3
Slow Build
Slow Build's Avatar
The vin# should be stamped into the frame near the power steering pump. In my case I found that the vin#'s were different on my cab and frame (Cab 64, frame 65).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-06-2010, 09:31 PM   #4
65Guy
ok thanks for the info. I will have to look at the vins I never knew that there was a vin on the frame but it makes sence.
