Old 03-06-2010, 01:10 PM   #1
Rat Bastid
Rat Bastid's Avatar
OMG what have i done??
well fellas,after watching you guys and a marathon weekend of OverHaulin,i decided that the 71 Super Cheyenne C10 out in the driveway was coming apart.After ripping all the bedliner out i found all the wood was rotted completely so thats where i started.After the wood was removed and skid strips and bed bolts it was time to get it blasted.Once bed was gone the wirewheel and pressure washer came out.A couple days later the frame was ready for clean and primed and painted.Man I hope this comes out as well as other trucks i see here......stay tuned for more
Rat Bastid is offline   Reply With Quote
Old 03-06-2010, 01:14 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: OMG what have i done??
Wow... nice looking project!
What are your plans for it?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-06-2010, 01:21 PM   #3
Rat Bastid
Rat Bastid's Avatar
well my plans thus far are remove and replace rockers inside and out,drivers side cab corner replacement,2 new fender,2 new doors,new wood for the bed,lowers will be tricky with these tires and wheels 18in 285-60 all the way around,i know nothing about backspacing so any help on that would be appreciate it....my bodyman is here so will talk later...thanx for taking a look
Old 03-27-2010, 11:26 AM   #4
Rat Bastid
Rat Bastid's Avatar
ok guys,there is 2 rear fender braces i am missing and am wondering if anyone knows the length of these braces? found the braces at pull a part but not sure if they are the right length.....the braces are located at the rear of the bed,they brace the bed sides to the frame or wheel tub in rear holding the lower bedsides in correct alignment down the sides.....thank you in advance
Old 04-01-2010, 12:19 PM   #5
Rat Bastid
Rat Bastid's Avatar
thought i would throw up some new pics for you guysName:  101_4028.jpg
Old 04-01-2010, 02:16 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
nice project! clean motor
what were the holes in the bedside for gas door and what else?
John
1999 Toyota Tacoma 4x4
Old 04-01-2010, 05:55 PM   #7
Rat Bastid
Rat Bastid's Avatar
was a fuel door on each side that we filled and the little hole was a camper plugin,heres some before pics
Old 04-01-2010, 06:06 PM   #8
john
member #16
john's Avatar
Nice project truck. What are those L brackets on the frame?
john is offline   Reply With Quote
Old 04-01-2010, 06:46 PM   #9
Rat Bastid
Rat Bastid's Avatar
thanks john.....the brackets far as i could surmise were installed to support a fifth wheel hitch im guessin....there were 3 holes on each wheel houseing also i had to fill....any way i removed the brackets yesterday as well as prepping for the motor and tranny to be pulled hopefully this weekend
Old 04-03-2010, 08:40 PM   #10
Rat Bastid
Rat Bastid's Avatar
motor and tranny out,frame wire wheeled and painted.....yay!
Old 05-10-2010, 12:07 PM   #11
Rat Bastid
Rat Bastid's Avatar
got too hang some new fenders and doors today,course fitment will need some bodyman love but am still moving forward
Old 05-10-2010, 01:05 PM   #12
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
seems to be getting contagious around here....
nice work!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-28-2010, 08:56 PM   #13
Rat Bastid
Rat Bastid's Avatar
a little update,have finished the bed and its in primer finally,been along time comin since the body guy cory had to have knee surgery and was down for a bit...
took the cab and chassis to his house for rocker removal and replacement as well as a drivers side lower cab corner replacement.....
in these pics you can see ive opted to remove stake pockets completely and have them filled in as well leaving a smooth bed rail....this will have new bedwood installed aswell as fiberglass tonneau should make for a leak free bed i hope,rains alot here in seattle
Old 05-28-2010, 09:22 PM   #14
br161
br161's Avatar
dont worry they do go back together just alot more fun and time involved in the reversal, looks great already good luck with project
br161 is offline   Reply With Quote
Old 05-30-2010, 09:15 PM   #15
freakshow108
freakshow108's Avatar
Nice to see a local guy going through what im going through. my son and i are doing a frame off resto on a 71 K20 and its been a blast so far! if you ever need any thing let me know im in the sumner area all the time and i have a 2wheel drive that im using for parts, mainly the body and motor, so if i can help let me know!
freakshow108 is offline   Reply With Quote
Old 05-30-2010, 11:51 PM   #16
Rat Bastid
Rat Bastid's Avatar
well thanks and nice too meet you,everything is goin smooth so far....have you met wes DOWN IN OLYMPIA......hes got it goin on down there has a nice shop and literally get anytrhing you might need for your rig,his shop is located off the 5 on exit 99 go east past case rd hes on the right,hope to see your build as it goes along......
Old 05-31-2010, 08:26 AM   #17
freakshow108
i think ive met him, i droped by a shop that specializes in our trucks, in the oly area, and yes i was like a kid in a candy store! good lukc on your rig, we are trying to be complete around his 16th birthday,nov 7 2011, so far we are on pace, but we are cautiously optomistic. money be damned!
Old 05-31-2010, 09:29 AM   #18
VA72C10
VA72C10
VA72C10's Avatar
Progress is looking good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-17-2010, 08:30 PM   #19
Rat Bastid
Rat Bastid's Avatar
got a bunch more pics for you guys, rockers were hashed up pretty good as well as the window channel.....
replacement parts went in smooth with very little alteration,got the right side off and realized more parts were needed like a pillar repair patch as well as 2 front cab supports. WES just happened to have everything i needed in inventory,some of you my know WES at classic heartbeat in olympia wa,hes been a source of alot of good info as well as awesome replacement parts.
Old 06-17-2010, 08:49 PM   #20
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Originally Posted by Rat Bastid View Post
ain these pics you can see ive opted to remove stake pockets completely and have them filled in as well leaving a smooth bed rail....
I've been thinking of doing this. Does it leave the top rail weak? I want to still be able to sit on the rail without bending it.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-17-2010, 11:09 PM   #21
thelonerife
thelonerife's Avatar
You really have been hard at work. I have had my share of that brown stuff. Looking good.
thelonerife is offline   Reply With Quote
Old 06-18-2010, 12:57 AM   #22
Rat Bastid
Rat Bastid's Avatar
not sure about sitting on the rail,thats something i WONT be doing,just wanted a cleaner look and think we have achieved that,got to keep moving on this project cause i dont like having my truck spread over 3 counties like it is now lol and thanks for taking a look and the comments too
Old 10-08-2010, 10:36 PM   #23
Rat Bastid
Rat Bastid's Avatar
update....motor came back all fresh and stuff keith black pistons,high tech light weight rods,roller rockers,bumpin cam.....bored 060 so is no longer a 402 ,its now a 410 lol
Old 12-30-2010, 09:29 PM   #24
RCbowtie69
RCbowtie69's Avatar
looking good keep pictures coming
RCbowtie69 is offline   Reply With Quote
