Old 03-06-2010, 03:46 PM   #1
Alex Hayley
booster & transmession vacuum locations
On the original engine, the brake booster vacuum location came off of the large port on the back of the carb while the transmission vacuum came off of a port in the manifold. The new intake (brodix) does not have a vacuum port. Can the brake booster and transmission share a port from the back of the carb? Notice that this port is manifold vacuum.
Alex Hayley is offline   Reply With Quote
Old 03-06-2010, 04:26 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: booster & transmession vacuum locations
The fitting for the booster and transmission are different sizes. If you can figure that part out it should be O.K. Mine came from the factory with both off a port on the manifold.
Can you run a tee off the line going to the distributor for the transmission?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
