Old 03-06-2010, 05:28 PM   #1
Bowed
Black grease in radiator
About a month ago I bought a 98 GMC short bed with a 305/auto and 85k miles . I notice the inside surface of the radiator is covered with a black grease . If I stick my finger down inside there and rub around , the finger comes out all black and greasy . I drew some coolant from off the top and even though it's not perfect , it's not all that bad either . There are no signs of oil in the coolant that I could see . The coolant level seems to stay constant and no drip at the tail pipe to indicate a head gasket. I also notice that even though the coolant level is exactly where it should be , every once in a while , right after the truck is parked , it spits out a little coolant on the ground . This slight spill is not coming from the reservoir overflow tube and no leaks are apparent at either top or bottom of engine , water pump , radiator or freeze plugs . It is not AC drip either , it's coolant . I am at a loss to where it is actually coming from and like I said it's not all the time . Well , do we have any ideas .
Bowed is offline   Reply With Quote
Old 03-06-2010, 05:47 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Black grease in radiator
Is there coolant in the oil?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-06-2010, 06:39 PM   #3
HarrisonTX
That is weird. I wonder if its some sort of "STOP LEAK" coating??
Since you say there's a leak you cant find, maybe the previous owner poured some stuff in there to "seal it up''?
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 03-06-2010, 06:51 PM   #4
clinebarger
On the coolant leak, its probably the intake gaskets. 96-98 vortecs are notorious for leaking intake gaskets. The black grease, im not sure. chould be sediment mixed with the dex-cool coolant. Even though it only has 85K its still 12 years old.
clinebarger is offline   Reply With Quote
Old 03-06-2010, 06:53 PM   #5
clinebarger
I agree, Trying to stop the intake leak.
Old 03-06-2010, 10:01 PM   #6
Bowed
Gary
Thanks for answering ... No coolant in the oil .
Old 03-06-2010, 10:33 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
What I noticed my '96 Silverado radiator neck had an orange crust in it and that the reservoir kept going empty, I figured out it was the organic antifreeze mixing with air that caused the crust. Replacing the intake gaskets solved the problem.
Now, if someone mixed the green and the orange coolants, could it produce that crud that you found? Maybe that and something like Bar's Leaks....
Member Nr. 2770
Old 03-06-2010, 10:42 PM   #8
Bowed
The coolant is not Dex , it's the yellow stuff . The small spill does not happen all the time , just once in a while and it lands directly under the engine . I can't find a coolant track anywhere . Thanks .
Old 03-06-2010, 10:51 PM   #9
Bowed
Sorry , I'm real slow at typing and didn't see your post before I answered Clinebarger . So .. yellow and red don't go together unless you want a messy radiator . Guess the PO didn't know that either . I will get a can of flush , clean it out and then replace the coolant . Thanks .
