03-06-2010, 07:08 PM | #1 |
Shake and Bake!
Hissing sound under load, Chevy 350.
Hey,
So I just started getting a hissing type sound when the truck is under load, and you get on it. I don't hear it when I drive it normal, but like when getting on the freeway, it sounds like it is sucking air somewhere. Not sure if it is just the normal sound of the air cleaner sucking more air or if I have a vacuum leak somewhere, I didn't notice it before. I have checked the upper vacuum connections, brake booster, distributor line, PCV, modulator (Upper connection) etc and all seem to be tight. Where to look next? Thanks Guys.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
03-06-2010, 07:22 PM | #2 |
Re: Hissing sound under load, Chevy 350.
Vacuum leaks are more audible when idling. I think you may have a restricted exhaust &/or an exhaust leak.
03-06-2010, 07:27 PM | #3 |
also it could be the gasket right under your carb that connects to the manifold. Make sure your carb is not loose. Spray a little carb cleaner around the bottom of the carb with it idling and see if it canges the idle of it. Will your in there make sure all the little rubber plugs arent cracked around the carb. You can spray there to
03-06-2010, 10:57 PM | #4 | |
Big Red - Now its a SWB!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
