03-06-2010, 07:23 PM | #1 |
Bed mounting pads
Is this a factory item or something that the aftermarket has determined really helps with noises on the truck?
http://www.classicparts.com/1954-87-...info/13%2D555/ |
03-06-2010, 08:30 PM | #2 |
Re: Bed mounting pads
It is an aftermarket item. I use conveyor belting to make the pads, cutting the squares out to fit and then punching a hole in them.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-06-2010, 11:11 PM | #3 |
Grandpa in the rustmobile...
so just a piece of rubber cut to size? does it help alot? or is it a waste of my time to make these (beds off currently)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-06-2010, 11:13 PM | #4 |
also interested in how much these would help
DJ |
03-06-2010, 11:56 PM | #5 |
My question is, does it screw with the body lines due to the added height? I get my truck back from paint on Friday, so we shall see.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
03-18-2010, 11:50 AM | #6 |
no one else had any answers for this? I think a fairly thin 3'16" piece of rubber would be just fine... think of how sagged out your cab mounts probably are already
03-18-2010, 02:26 PM | #7 |
Under Construction
I heard the bed pads were standard on. Cst's !
I have them on my sons '67 .
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-18-2010, 03:35 PM | #8 |
I talked to Paul from GMCPauls today about an order I placed. One of the things I ordered was the cab and bed mounting kit. I asked about the bed pads because it was an option. He said that these are typically used to keep the bed bolts tight. If you drive down bumpy roads a lot the bolts come loose and the bed rattles. If the bed is tight to the frame I doubt there is much noise. My truck is a street truck that I'll occasionally drive down a farm road to go hunting so I opted not to use them.
Blayne |
03-18-2010, 04:08 PM | #9 |
i've alwas made my own out of 1/8rubber ssheet stock//i figuered it wouldn't hurt cost about nothing to make took about 5minutes to fabricate a set so it was cheap insurance against mystery squeaks from metal on metal contact
03-18-2010, 04:31 PM | #10 |
I would think that it would mess with your grounding also
1967custom |
03-18-2010, 04:36 PM | #11 |
I drive alot of gravel. Will it mess up my body lines? And could someone answer the grounding ?
03-18-2010, 04:49 PM | #12 |
I am a Referee of life.
A simple grounding wire would fix the ground issue.I would put them in just as a precaution.I don't think I want a squeak and they are cheap or free so........
I sure wouldn't want to pull a bed just to install them because I had a noise.I doubt the 1/8-3/16ths would make a lot of difference in alignment and it should be easy enough to add that under the cab mounts if needed.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 03-18-2010 at 04:50 PM. |
03-18-2010, 05:45 PM | #13 |
those bed mounts are a poor sourse of gronding anyway// a ground strap from the crossill of the bed to the frame is the foolsproff way to get a good ground connection,it's been proven quite a few times in the electrical section over the years
