Old 03-06-2010, 07:59 PM   #1
sand rocket
Gauge cluster housing
Anyone know of a place that the greenish plastic housing is avaiable. I have a 79 with the factory tach. I have searched the yards here and have not found anything.
sand rocket is offline   Reply With Quote
Old 03-06-2010, 11:26 PM   #2
b454rat
Re: Gauge cluster housing
You can use a non-tach housing, just need to cut a small hole for the back of the tach to fit. Swap circuit board over and gauges, install in truck, drive around with a factory tach. Bang zoom, get er done....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 03-06-2010, 11:35 PM   #3
sand rocket
What about the fuel gauge? Most of the ones i find here are the ones with clock or nothing?
Old 03-07-2010, 10:04 AM   #4
b454rat
You will need the small gauge, but if you got a steady hand, you can take the rivets out, and screw on a small face off a temp gauge or something, then get overlays and put the small fuel gauge to cover the temp or whatever one you use. The motors are the same between the large and small fuel gauge.
