Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-06-2010, 08:20 PM   #1
1971gmcshortbed
1971gmcshortbed's Avatar
Mickey Thompson street radial II
Well after figuring out that I dont want to run 18X8's all the way around, I started looking around. I originally wanted Mickey Thomson Sportsman S/R tires. But after realizing that I cant afford new wheels I called Boyd Coddington wheels.
They can "re-hoop" 2 of my wheels for a not so bad price. I can go from 18X8 to 18X10 or 18X12, I figure if i'm gonna spend the loot I may as well go as wide as I can. However a Sportsman S/R is not made for a 12" wheel (on an 18"). So another tire I found the Mickey Thompson ET street radial II's. I can only find a handful of 345/35 18's. Most are track tires. The ET street radials have a 000 treadwear. So basically they wear out real quick but they stick good.
There are many 335/30 18's but I think they are too short. I would like at least 3 or 4 inches of sidewall. What do you guys think? Has anyone seen a more "streetable" 345/35 18? The pic below is the street radial II I believe the ones on the left are the 345/35.
Anyone have any experience with this or a similar tire? How long do you gus think they will last? Considering I won't race it or drive it real hard. It will have the power but i'm too old to be hot rodding around.
1971gmcshortbed is offline   Reply With Quote
Old 03-09-2010, 04:53 AM   #2
Super73
Super73's Avatar
Re: Mickey Thompson street radial II
I run a MT ET Street radial, but in a 315/60/15.. I can't say exactly how many miles are on them, but I'd say at least 800 or so with several decent burn outs.. They do hook pretty good (but I also work on my suspension a lot).. They don't seem to be showing a lot of wear yet.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-09-2010, 07:11 AM   #3
Wild83C10
Wild83C10's Avatar
They should last a few thousand miles if not more. I probably had 2-2.5k on mine when I took them off and they had plenty of meat left on them. They are good dry traction tires and the side walls are sitff enough for some hard street driving. I will most likely end up with 305 or 315 18" MT DRs.
The 345s looks awesome.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-09-2010, 12:07 PM   #4
nomrlz
nomrlz's Avatar
if you don't do burnouts. these tires should give you maybe up to 10K miles. and you're gonna need a helluva motor to turn em anyway. these things will stick on blacktop. they aren't that great in rain but you'll survive with em.
nomrlz is offline   Reply With Quote
Old 03-09-2010, 10:09 PM   #5
1971gmcshortbed
Thats exactly what I wanted to know. The other 345/35's I saw were MH Racemasters. They are about the same price. I'll probably get the Mickey Thompsons. If I get 10k miles out of them i'll be happy. Thanks for the responses. Thank you 6772.
Old 03-10-2010, 08:23 PM   #6
raveer2000
raveer2000's Avatar
Toyo makes a drag radial
http://www.racetire.com/products/toyo_tq.htm
1972 K5 CST. Work in progress. 408CI
1980 K10
raveer2000 is offline   Reply With Quote
