![]() Join Date: Nov 2008
How Many Bolts to Remove Front Clip?
Need advise or steps in removing a front clip on a 72
1970 ![]() 1971 ![]() 1971 ![]() 1972 ![]() 1972 ![]() 1999 ![]() |
Running on empty
Re: How Many Bolts to Remove Front Clip?
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
![]() Join Date: Apr 2008
Here's how I do it - Remove the following: wiper arms,cowl vent,front wheels,inner wheel liners,bumper,radiator, & battery. Then I remove the radiator support bolts (the 2 big ones that go to the frame) & unplug the wiring harness at the firewall (1 bolt in the center needs to be removed then it unplugs). Make sure all other small stuff is unhooked ( alt. wiring, wiper fluid line, etc.) then remove the 6 bolts that hold the fenders to the cab ( 4 at the top & 2 at the bottom). I leave 2 of the uppers in (1 on each side)until I have some help - 1 person to gun out those last 2 bolts (wife works good for that job) & another guy to grab the other fender. We (the 2 guys) then can just pick up the whole doghouse (hood & all) & lift it off the truck. This usually can be done in about an hour using the air gun. Hope this helps!
#4 | |
