Old 03-07-2010, 12:52 AM   #1
4milbanshee
4milbanshee's Avatar
68 chevy 2wd short bed, s10 springs?
i have a 68 chevy 2wd short bed pick up,im putting 396 big block in it but im not sure if putting s-10 front springs in it would be a good idea, i dont know if the s-10 springs are going to be able to hold the weight of the big block, got any suggestions of what springs to use???
4milbanshee is offline   Reply With Quote
Old 03-07-2010, 01:27 AM   #2
4milbanshee
Re: 68 chevy 2wd short bed, s10 springs?
i need help with some suggestions
Old 03-07-2010, 02:49 AM   #3
EA69TRK
EA69TRK's Avatar
heres a bump for yah hope it helps
1969 Chevy C10 Short Step -Project
2005 GMC Sierra Crew Cab 1500 -DD
2017 Laguna Orange Roadglide - Good Weather DD
EA69TRK is offline   Reply With Quote
Old 03-07-2010, 03:50 AM   #4
jbristo67
resident oilfield trash
jbristo67's Avatar
I do know a 396 weighs twice as much as a 350.....................Not sure if this helps at all
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-07-2010, 03:59 AM   #5
darthwall
not sure but I wouldn't think they would just use sb springs and the height diference is about 3" from bb springs if your trying to drop it
darthwall is offline   Reply With Quote
Old 03-07-2010, 06:33 AM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
4mil,we can better advise you with more info.What will you be using the truck for?What is your goal? How do you want the truck to ride?
Generally it's best to stick with factory style springs from one of the after market vendors.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-07-2010, 02:13 PM   #7
powell72
powell72's Avatar
Will an S-10 spring even fit in the pocket of the control arms or crossmembers in our trucks? I honestly don't know. I don't think this sounds like a good idea, if you are looking to lower it on the cheap, I'd use small block springs from our trucks and maybe cut a coil to fine tune the height.
You should be able to find someone who would give you a set for nothing.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-08-2010, 12:22 PM   #8
4milbanshee
i was told s-10 springs do fit in our trucks, but im just not sure if they will be able to hold a 396
Old 03-08-2010, 01:25 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Drop the big block in and see how it sits first. Then go from there. Everyone I have talked to says dropping in a big block with your factory springs only drops the front end about a 1/4 inch from where it sat with a small block in it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-08-2010, 01:46 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Iron small blocks weigh 575 pounds average. Iron big blocks weigh 685 pounds average.
http://fixrambler.com/engineweightchart.txt
http://www.team.net/sol/tech/engine.html
http://www.gomog.com/allmorgan/engineweights2.html
Old 03-08-2010, 01:51 PM   #11
jbristo67
jbristo67's Avatar
oh well we will blame that miss info on kgb
2011 Nissan Armada
Old 03-08-2010, 02:26 PM   #12
epashhans
epashhans's Avatar
I am kind of curious what your intentions are with using s-10 springs? Are you looking to gain something? Did you get them for free? Do you not have the original springs? This is a new one to me...I didn't know you could use them, but thats cool. Seems like something I wouldn't want to do...a small pickups springs in a full size with a big block.
My 67 had cut stock springs and it was originally an inline 6 but had a 454 in it. It worked okay. I got some 3 inch drop springs in it now...they were pretty cheap and specifically built for this pickup. Not as cheap as cutting originals, but if you can swing it I would just get springs that are meant for these trucks...you will be glad you did I think.
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
