Old 03-07-2010, 01:37 AM   #1
siksilverado
help help help
guys i got a 67 cab and bed and the whole front end but i do not have a frame to sit it on...do you guys know if i can use a newer frame truck and how difficult would it be to do it if any major work thanks
SAL
siksilverado is offline   Reply With Quote
Old 03-07-2010, 01:55 AM   #2
siksilverado
Re: help help help
any body?
SAL
Old 03-07-2010, 02:14 AM   #3
EA69TRK
EA69TRK's Avatar
Re: help help help
yes you could put it on a newer frame by transplanting the body mounts not sure on the diffucutly though sorry.
1969 Chevy C10 Short Step -Project
2005 GMC Sierra Crew Cab 1500 -DD
2017 Laguna Orange Roadglide - Good Weather DD
EA69TRK is offline   Reply With Quote
Old 03-07-2010, 02:16 AM   #4
leatherman
Re: help help help
Sorry I can't help, that's one of the many questions I have too. I'm watching this thread to see what they tell you. The guys in the know must have done gone to bed. I've got a 76 4x that I'm wanting to use the frame out from under. Good luck!
leatherman is offline   Reply With Quote
Old 03-07-2010, 02:28 AM   #5
Leviticus
Shake and Bake!
Leviticus's Avatar
Re: help help help
I see you are in Cali, I just talked to a guy the other day near me who has a 67 or 68 frame can't remember exact year. He will let it go cheap IIRC. I can try to put you in contact with him.
Also, as far as later frames I had a 1965 Carry All that was on a mid 90's frame, I didn't build it but I finished it. From what I could see it was some work. I always see it as easier to do the upgrades to your old setup, as far as disc conversion etc. But a lot of guys do it.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 03-07-2010, 02:30 AM   #6
GruntMoanCough
GruntMoanCough's Avatar
Re: help help help
I've done three of them, on Blazer frames, though. With the Blazer frame you end up with about a 2" body lift 'cause of the rise at the rear. I think you would be OK with a pickup frame.
The crew cab I'm building is on a '80 frame and if I remember correctly the box fit good.
For the cab:
Rad support mounts are moved back to the two rear spring hanger holes.
Front and rear cab mounts have to be moved or fabricated.
Steering and brakes aren't much of a problem.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 03-07-2010, 02:30 AM   #7
Leviticus
Shake and Bake!
Leviticus's Avatar
Re: help help help
Also, the one thing I remembered he said was it had the tranny cross member removed at one point, can't remember if he still had it but can't be that hard to track one down.
Thomas Jefferson
Old 03-07-2010, 07:19 AM   #8
siksilverado
Re: help help help
Yea see i wish i had the original frame but i dont it would b so much easier but my friend offer me the body parts so all i need is the frame and i know of a guy that has one for about 200 bucks which is not bad at all but i still gotta get a pink for the 67 cab cus he dont have one..i got my 68 2wd that im working on too so i gotta finish one up first and then the other one your guys info is great if you get any more just let me know thanks alot
SAL
