fitting question
i have a question for my fellow board members. i am currently trying to convert my stock steel trans. lines over to braided or rubber pressure line, the original steel lines were 7/16 just like many vehicles of that era. i ordered my fittings and hose ends from jegs the other day but the fittings were to large. i ordered 1/2 pipe to -6 an fittings, but the pipe end was way to large. when i measured the steel lines fitting it appeared to be 1/2 , is pipe measured by the id and not the od? if anyone has made this conversion suggestions would greatly help.
'71 LWB c10-"WORK" in progress ![]() 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
Re: fitting question
Id
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
Yep. Pipe threads are ID. If you are unsure of the thread size you could take the fitting you are trying to match to your local Lowe's or Home Depot. They always have a display to verify thread size. It will be in the plumbing section near the brass fittings.
Active Member
![]() Join Date: Jun 2002
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
its all about the +6 inches
i am 99% positive they are 3/8
If you have a th350 trans the fittings that go into the trans are Aeroquip #fbm 2111 this fitting will thread into the oe trans fitting and will convert to 6 an. You will need 4 of this number the other 2 will go in the radiator. You will also need 4 6an fittings for the hose. Then all you will need is 6 an hose what ever length.
http://www.summitracing.com/search/?...=fbm2111&dds=1 http://www.summitracing.com/parts/SUM-220690/ hope this helps Last edited by hayhauler71; 03-07-2010 at 03:46 PM. |
cool thats exactly what i needed to know, i already have the -6 an hose fittings and hose. the rad and trans fittings were the wrong size. thanks a lot
