Old 03-07-2010, 03:15 PM   #1
WHAMMYBAR66
WHAMMYBAR66's Avatar
Question Water pump help...
Hey guys.. I am converting my 69 blazer over to a serpintine belt system. I have done this before for my '66 k20, but that truck had one of the heater hoses going to the radiator, not to the water pump. That conersion was easy !
I am needing to find a part number for a reverse flow (counter clock-wise) long water pump that has a heater hose port on it. Everything I am seeing is without ANY heater hose port on it. Any help would be appreciated as my radiator doesn't have any type of heater hose tap on it, I need to keep my heater hose connection at the water pump.
I know one it out there, and it can be a factory type pump.. I don't have to have an aluminum fancy thing...
THanx!
whammybar66
WHAMMYBAR66 is offline   Reply With Quote
Old 03-07-2010, 07:21 PM   #2
KFreddy
Active Member
KFreddy's Avatar
Re: Water pump help...
This should work, FlowKooler #1974, is a reverse rotation, not reverse flow, long water pump with heater hose ports.
I think that these pumps might have heater hose provisions and might be less expensive.
Edelbrock 8881
GM p/n 88894005
FlowKooler 1774
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 03-08-2010, 01:50 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
get one for a 1994 K1500 with the 4.3. I'm standing here at work looking at one.
68C15 is offline   Reply With Quote
Old 03-08-2010, 02:32 PM   #4
monte0185
monte0185's Avatar
A 1999 Tahoe with a 5.7 will have one too. Actually it has 2. One that goes to the intake and one to the heater core. Good luck.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-08-2010, 07:30 PM   #5
68C15
blood type; Retumbo
68C15's Avatar
this is partially true. it does have 2 but they are both pressed in tubes and may interfere with other brackets. the one I mentioned is physically identical to what our trucks came with (aside from being longer)
Old 03-08-2010, 09:25 PM   #6
matt67350
matt67350's Avatar
You can have a return installed in your radiator. Any radiator shop can do this.
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 03-08-2010, 11:48 PM   #7
67-C10
67-C10's Avatar
i just picked up one for my serpentine setup which came from a 88 1500 with a 305 and it had the spot for a barb fitting but came with a plug in it but don't see why you couldn't change it, i'm gonna do the same thing down the road anyway too just really aint mobile yet. got it at autozone for $29 and painted it up.LOL.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now.....
Needed: paint and lots of it. and i'm sure lots more misc. parts.
Project 67 short step Build Thread
01 Sierra Crew 6.0
2015 Ford F150 Work gave me truck i really wouldn't buy a ford.
67-C10 is offline   Reply With Quote
