Old 03-07-2010, 06:51 PM   #1
layingC10nK5
which rear end??? please help!!!
ok guys i just got a rear set up from porterbuil. it the one to lay frame with his tubular trailing arm. i got to weld the brackets so i need help deciding what rear end to use, i got the original 68 6-lug a 5-lug from a 71 4x4 k5 (i converted to 5 lug) and one from a 98 z28 camaro with posi and disk brakes.
please any input will help me out. thanks in advance.
layingC10nK5 is offline   Reply With Quote
Old 03-07-2010, 07:20 PM   #2
GVizzle
GVizzle's Avatar
Re: wich rear end??? please help!!!
I have the same setup going on my truck in the rear, and Nate's using a 67 six lug 12 bolt rearend (converted to five lug) and my rear wheels have a 5.5 Backspace. It will be posi also.
That rear end is 56.5" flange to flange.
Hope this helps.
GVizzle is offline   Reply With Quote
Old 03-07-2010, 07:32 PM   #3
layingC10nK5
is that measurement for a 68 rear end or a newer like the 72? i know the 68 is shorter but will cost over 300 for five lug axles. like most of us im trying to keep cost down. the camaro rear is 64 inches long so i guess its between the two older ones
Old 03-07-2010, 07:44 PM   #4
AusTruck
FWIW, the 98 Camaro rear end is based on the GM 7.5 or 7 5/8" rear gear set. This is one of the weakest gear sets ever put into a Camaro. If you're going to run pretty wide rear tires with some decent grip and making decent HP, this rear end is risky. I know guys have drag raced them, but a lotta guys with stock motors have blown these Camaro rears up. They're plentiful and cheap, but way below the strength of a stock truck 12 bolt. Positraction is fairly common as are disk brakes, but these rears aren't long on strength.
I've got a 94 Camaro Z28 with that same rear end.
AusTruck is offline   Reply With Quote
Old 03-07-2010, 07:50 PM   #5
layingC10nK5
thanks for the reply. i got the rear end as part of the deal when i got my ls1 and 6l60e drivetrain. i want the posi and disk but im pretty sure its now between the other two rears. im leaning more toward the 71 5 lug i know it wider but just need to measure to see how much the difference is.
it will either be the 71 5lug with 71 5lug front or the 68 6 lug with 6 lug disk up front.
can the 6 lug be made posi??
Old 03-07-2010, 08:03 PM   #6
GVizzle
GVizzle's Avatar
I think it went from 56.5" to 58" somewhere between 1970 and 1971. I've heard of 1970 axels being 56.5 and 58.
You can get a way with the wider axel you will just have to run a different offset. I wanted a 10" rear wheel for my 285 tires to roll with out rubbing tucked so we needed the narrower rear.
I guess it all depends on your wheel and tire combo, but the narrower rear will give you the most options if you can swing it.
Eric-
Old 03-07-2010, 08:11 PM   #7
layingC10nK5
ok so its 3/4 of an inch to each side correct??
the shorter axles cost over 300 is it worth it for that 3/4 inch?? thats where im having problems deciding.
thanks for ALL replies
Old 03-07-2010, 08:14 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: which rear end??? please help!!!
The narrower axle is a plus if you want to run deeper wheels on the rear. What wheels are you planning on running?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-07-2010, 08:19 PM   #9
GVizzle
GVizzle's Avatar
Don't forget you can have your six lug axels re drilled for less than 300 USD.
It was worth it to me.
I spent alot of money on all PB stuff and I wanted to have it right the first time. (For the wheel and tire set up I am going with)
Old 03-07-2010, 08:22 PM   #10
layingC10nK5
i will hopefully lay on 24's all around, nate made the notch so that it can lay a taller tire, the front will be dropmembered with a 2 inch Z. i would like 24X12 in the rear but 24X10 minimum
Old 03-07-2010, 08:30 PM   #11
GVizzle
GVizzle's Avatar
Then for sure the narrower rear.........
Old 03-07-2010, 09:02 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
There's your answer.
Articles-
"Refining Sierra"
68 shortbed, rear end
