03-07-2010, 07:35 PM | #1 |
Carb or fuel injection?
Carb or tbi? I don't know what to do. I drive on the highway almost everyday and I either need a new carb or to spend the money on a tbi. In Vegas when it's 120 outside and 170 on the street the carb acts up alittle. I'm not a mechanic by no means and just want to enjoy the ride of my old 79. Please help.
03-07-2010, 07:59 PM | #2 |
Re: Carb or fuel injection?
INJECTION hands down!!! IMO carb are outdated !
78 C-10 5.3 LSX -4L60E Last edited by 78-5.3; 03-07-2010 at 07:59 PM. |
03-07-2010, 09:11 PM | #3 |
injection...as the member name above reads.. 5.3 is the way to go.. how is that saying? once you go ls!! you never want less!!!
03-07-2010, 09:16 PM | #4 |
BAD BOW-Silverado XST
I drive a carb. Get 18+ MPG at 70 MPH. Carbs are outdate but they do work when properly adjusted and setup.
Without an engine transplant, aftermarket TBI/MPFI installs are available. Read this article: http://users.sfo.com/~eagle/howell.html You'll get a good idea about using stock parts from a donor vehicle. You can even upgrade a few parts for better performance. You can buy parts from http://www.cfm-tech.com/ |
03-07-2010, 09:20 PM | #5 |
also gchemist is right on the properly tune carbs
ONCE YOU GO LS, YOU NEVER WANT LESS!! |
03-07-2010, 09:21 PM | #6 |
this post is just to change the email notification option
03-07-2010, 09:23 PM | #7 |
Happy to be here
Sounds like you just need someone to tune your carb properly. I prefer injection, but there is nothing wrong with a properly tuned carb.
03-07-2010, 10:38 PM | #8 |
What would be the best injection set up for my chevy 350 5.7
03-08-2010, 12:14 AM | #9 |
Is the motor modified? If so, a Ram Jet setup from GM is perfect.
http://www.summitracing.com/parts/NAL-12498032 If the motor is stock, a TBI/TPI setup works fine. |
03-08-2010, 12:32 AM | #10 |
an LS based engine is just more hassle free.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
03-08-2010, 12:40 AM | #11 |
haha, ford guys...
with wild heat swings the carb is bound to be UN-EFFICIENT carbs do not suck. Theres a reason people still use them. Emphasis on the word UN-EFFICIENT...
You should look into the edelbrock kit or a complete swap. |
