Old 03-07-2010, 10:55 PM   #1
Andrew68c10
TH400 Tailshaft Housing
I need to replace the tail housing gasket on my TH400. Has anyone done this? Does the tailhousing cover any gears or anything else that may come apart?
1968 Chevy C10 Longbed Fleetside
Andrew68c10 is offline   Reply With Quote
Old 03-07-2010, 11:10 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: TH400 Tailshaft Housing
Covers the speedo gears, just take out the worm gear out the side and pull it apart. The round gear shouldnt come off unless you try to pry it off. Should have the clip in it to keep it on the shaft.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-08-2010, 07:53 AM   #3
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I changed mine out already once just support the transmission because once you pull off the Tailshaft Housing to replace the gasket the tranny falls a couple of inches because thats what supports the tranny. Then make sure you have something to catch all the oil that is going to fall out. their is some gears in there but they will not be affected by the change of the gasket so you can't mess anything up, nothing will fall out only oil.. Ok heres a picture of mine when I had it uncoverd it might be upside down though but you can still see inside. The only thing that might be different in yours is the shaft mine is messed up. Hope this helps.Pablo
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
