Old 02-03-2003, 03:58 AM   #1
RON WOODGEARD
Resident Young Old Dude !
Question Shorty headers
After lowering my 70 C-10 4" & 6", I'm concerned about the headers hitting on the street.
Who makes "shorty" headers for these years? I don't care of they're chromed or not, The chrome usually Burns dark anyway.
Just good quality Shorties.
RON
RON WOODGEARD is offline   Reply With Quote
Old 02-03-2003, 06:33 AM   #2
GMCPaul
Thumbs up
ll of these trucks I have seen using shorty headers are using block huggers or 88up truck that I have spoken with. Tons of manufacturers of both styles.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 02-03-2003, 09:41 AM   #3
crazy longhorn
Fabricate till you "puke"
Some of the guys are running 3/4 lenght chevelle headers, & they seem to fit pretty good. Im not sure how they work out with a stick trans tho....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-03-2003, 02:36 PM   #4
RON WOODGEARD
Thanks guys,
Paul,
I'll go the 88 up route.Thanks!
RON
Old 02-03-2003, 02:42 PM   #5
Slammed67
Progress = 0%
Slammed67's Avatar
These are Sanderson block hugger headers........a little pricey but you get what you pay for.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 02-03-2003, 03:38 PM   #6
Mike C
Mike C's Avatar
With the motor in the setback position like slammed '67 (that's what I would do, too!) you should be able to use 67-72 4x4 headers. The Heddmans exit above the bottom of the frame rail. If you have a coil spring truck, you can route the exhaust through the crossmember keeping all of it above the bottom of the frame. I've got the set that came from my Jimmy if you want measurements, email me.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-03-2003, 04:09 PM   #7
RON WOODGEARD
Again Thanks guys,
I believe, my engine is set back, I'll check to be sure, and I had the exhaust run through the crossmember when I had the exhaust done the last time, 10 or so years ago.
I'll do this once i get moved and set back up, But wanted to be aware of my options.
Slammed,
where did you get the "Sandersons"?
RON
Old 02-03-2003, 11:45 PM   #8
DevinM
DevinM's Avatar
How can i tell if my trucks engine is "set-back"? It originally came with a 350, however i think that it has been taken out and rebuilt.
'71 Chevy C-10 - Current
'62 Imapla SS - Traded for my current
'73 Nova Hatch - traded for ATC-350X
'73 Chevelle Deluxe - First car (R.I.P)
DEERFIELD, MA
DevinM is offline   Reply With Quote
