03-07-2010, 11:46 PM | #1 |
BBC Motor Mount, Please Help I.D.
I just pulled the 402 big block from my 71 C10 and noticed the rubber mounts on the frame are stamped made in Korea. Should I keep these or swap them out for some poly mounts? The driver's side is stamped #2395. Can someone tell me what year mounts I have?
03-07-2010, 11:48 PM | #2 |
Re: BBC Motor Mount, Please Help I.D.
Those look like 73 and up BB motor mounts
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
03-07-2010, 11:53 PM | #3 |
They look almost new but I am wondering if I should swap them out for something better as long as the engine is out. I am not sure if there is something better, polyurethane maybe.
03-07-2010, 11:56 PM | #4 |
I Like Mine With No Shine!
Your motor mounts and stands are 1972. One year only.
Michael 1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day) 2006 GMC Sierra Crew Cab 4x4 1969 Lincoln Continental Coupe Project FOR SALE http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 1981 Honda CM400 C Bobber SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
03-08-2010, 12:01 AM | #5 |
Roadtrip!
Look like the 1972 stands. Just buy some new mounts as long as it as apart and you should be fine if you are worried.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-08-2010, 07:40 AM | #6 |
"THE GREEN GOBLIN"
X2 1972 motor mounts and stands. You can replace the motor mounts by buying 78bigblock mounts, I might be wong on the year but you can get them new I did they are not that expensive neither.
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
03-08-2010, 11:24 AM | #7 |
Watch out for your cornhole !
I agree, they are definitely 72 only big block mounts. A lot of folks get them confused with 73-87 mounts since they look similar.
The way you can tell the difference is by looking at the raised lump on them where they sit on top of the frame. 72 big block mounts like above have one raised rib, 73-87 have two raised ribs.
03-08-2010, 12:24 PM | #8 |
those are exactly the same mounts that i have for my 68 and im wondering the same thing what yr mounts are they?
03-08-2010, 01:19 PM | #9 |
Moderator
As stated above, these are 72 BBC mounts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-08-2010, 07:32 PM | #10 |
I have not been able to find a polyurethane mount for the 1972. Does anybody have a part number?
03-08-2010, 08:48 PM | #11 |
One more for 72, 73 up have two humps on the stand 72 have only one. Any of the clam shell inserts in poly should work as replacements for your mounts, the inserts are the same from 72 up.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
03-08-2010, 08:49 PM | #12 |
Moderator
LMC carries the BBC poly mounts for 72.
03-08-2010, 08:56 PM | #13 |
They are 72 BBchevy mounts. Check Napa Auto Parts.
69 swb stepside, rebuild and upgrade in progress |
03-08-2010, 09:01 PM | #14 | |
03-08-2010, 09:41 PM | #15 |
I scored a set of these at a local swap meet sunday for $160. I can't decide if I want to put the 402 I have in my truck now
03-09-2010, 12:55 AM | #16 |
Recovering 67-72 Addict
I used some extra inserts that I had from my 73 Camaro in the 72 truck mounts. Same deal.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" Last edited by breeh; 03-09-2010 at 12:56 AM. |
03-09-2010, 01:31 AM | #17 |
2WD Jimmy
Yep... Ive got 72 mounts in mine and have poly inserts. I beleive the inserts are the same for a number of years after 72. I beleive mine are Pro Thane or shoot I cant remember... The company with the yellow and black box... someone help me out here...
03-10-2010, 12:39 AM | #18 |
I saw some Energy Suspension (pn 31116) poly insert mounts on the shelf at the local speed shop and decided to try them. The box said they fit a late model Chevy. They looked about right but ended up being too thin.
