Old 03-08-2010, 01:11 AM   #1
WorkinOnIt
WorkinOnIt's Avatar
Cool New girl with a new project
This truck was my dads project/daily driver about 8 years ago, went to my uncle about 6 years ago, and now that i live with him its now my project.
As a highschool junior I'm not going to have a lot of time during school but My goal is to finish by graduation..
So, I have absolutely no clue where to start, obviously this will be low budget to start. But i want this to be a kick ass truck in the end.
Its a 71' C20 long bed.
Under the hood currently I have a 350 thats been started once.
Normal rust in all the normal places for this truck, Ill be replacing Floorboards
Solid body
I have all the parts, except the core support and outer right fender
All in all it s actually in better shape then the GMC (Last picture) taking into consideration body and repairs needed.
70' GMC K15.... I believe
I want some ideas on where to start! i really don't know what to do..
WorkinOnIt is offline   Reply With Quote
Old 03-08-2010, 02:27 AM   #2
nuke1
nuke1's Avatar
Re: New girl with a new project
Nice start tp a great project. I was close to your age when I started mine, as to where to start, it really depends on what you want, how far you want to go, when you want it done ,and how much money you have. Figure that out first and go from there. Just a simple driver. or a full on Hot Rod. A frame off, or just make it work? think about this and then come up eith a game plan and stick with it.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-08-2010, 10:37 AM   #3
Slick67
Sofa King Crazy!!
Slick67's Avatar
Nuke is right. I am assuming you do not have a license yet so you can start with essentially whatever you want IMO. Mechanical is always the best place to begin, all the shiney stuff is best to do later. Great starter! Keep us posted!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 03-09-2010, 01:24 AM   #4
WorkinOnIt
WorkinOnIt's Avatar
As for where its going, Its not quite going to be a hotrod not quite just a simple driver. I'm not going to lower it to the floor because with it being a 3/4 ton im still going to use it to haul but, i still want it to look good.
But my thought is do i start with the engine which just needs to be refreshed or go and start with breaks, rotors and such before even looking at the engine?
I have to take out the main gas tank because i was informed that when it was driving it leaked in the cab, so I'm thinking it will be easiest to tear down to the frame and work it that way..
I know I sound like an imbecile but in all reality I am when it comes to restoring anything and I'm still in the thought process of all this until spring break but i can use any help i can get.
Old 03-09-2010, 01:50 AM   #5
capev86
network, network, network.....
i'm sure you can use all your charm and find lots of buddies to help you on your restoration. i also like how you plan to go mostly traditional on your build up. classic vehicles are best appreciated when revived not hacked into something totally different. there are plenty of ways to show some flair and make it fun to drive. on my 72 burb 3/4 ton i have replaced the rear trailing arm and panhard bar bushings with poly, added a sway bar and installed braided brake hoses. i do believe in upgrading for the sake of safety or using a material that will last longer and/outperform the original.
i'd say get the truck running for now and safe and legal to drive on the road. in the years ahead find yourself a cheap, efficient economy car that will cost next to nothing to run while you restore your truck. i use Classic Performance Products for my poly bushings (3/4 ton's have a bigger panhard bar and thus bigger bushings that CPP carries unlike the others) and LMC and Jim Carter for almost everything else. i am adding the factory tach and vac gages to my truck 'cause i want all the factory bells and whistles and plan to work my truck (tow trailers). my burb doesn't have much rust but parts can still be expensive. also don't forget the value of craigslist, ebay and even the local classifieds. some parts can be adapted from a newer truck. a 1-1/4" sway bar can be had from a some 3/4 and 1 ton trucks from the 73-87 body style. it will bolt right up. if your truck doesn't already have a 1-1/8" bar you might as well put on the best you can get.....super cheap junkyard hop up. handling is sooo much more predictable with a sway bar.
the guys (and gals) on here are a bunch of knuckleheads (like myself) but between the lot of us we got these classic trucks just about figured out!
capev86 is offline   Reply With Quote
Old 03-09-2010, 01:57 AM   #6
WorkinOnIt
WorkinOnIt's Avatar
Thanks Capev, That's the kind of info I'm looking for. LMC is my best friend and I didn't know about Classic Performance Products but I'll definitely look into them.
Does anyone know what if any parts i could take from the GMC? I'm not positive I can steal from it, but I looking at all my options.
Old 03-09-2010, 03:37 AM   #7
capev86
yeah......CPP is awesome. they are out in cali, so i can order from them at dinner time here in maine. most of what they carry is custom chassis pieces for hot rods and a lot of trick bling parts but there are a few bits like the poly kits that will look stock but be an upgrade at the same time. i have a pair of billet tie rod adjusters that i need to get installed and still need to order the polygrahite (burb specific) body mount kit they carry. polish the chrome, a wild paint job and some nice rolling stock is all the bling these old girls could ever need.
as for Jim Carter. they sometimes have better prices than LMC and they carry a full add on kit to add the vacuum gage to the stock dash, among other things. i got a 4 core radiator from them for 90 bucks cheaper than lmc's price. it is always good to shop around. if your engine is in bad shape, just find a good temporary donor engine to get you by. a 305 may not seem like a hot ticket, but throw a stock q-jet at it and it will get you around no problem and probably beat a 350 in gas mileage. it has the same crank as the 350 and they are a dime a dozen 'cause everyone wants a 350. my dad ran a '77 monte 305 in his 72 burb with an rv cam, rebuilt q-jet and dual exhaust with stock ram horn manifolds and we pulled our 6,000 pound trailer all over the place.
you could always build a 383 for your truck down the road. also, don't forget other cool mods like a roller valvetrain. heck, i put a petronix electronic kit in the stock distributor on the 307 in my burb 'cause it just plain makes sense. i have a 406sbc to throw in my truck eventually, but that is in the future after all the other work is done. it seems aspirations always get ahead of money and time!
Old 03-09-2010, 03:44 AM   #8
WorkinOnIt
WorkinOnIt's Avatar
As for the engine. Its staying (lest my uncle decides to take it back) Its actually a virgin on the inside.. i keep getting different stories.. but now i know its never been ran. ill stick with it
-Tasha-
71' C20 longbed w/350{Project}[[looking for a name!!]]
"I am not young enough to know everything."
"I know the price of success: Dedication, hard work and the unremitting devotion to the things you want to see happen"
-Frank Lloyd Wright
Old 03-09-2010, 04:38 AM   #9
OARNGESI
OARNGESI's Avatar
Nice start are you taking 2 to make one
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-09-2010, 04:23 PM   #10
WorkinOnIt
WorkinOnIt's Avatar
At this time no. I dont need parts from the GMC because I do have the parts i need.. The option is always there. I might just end up fixing both of them and the Yota.
We will see where life goes.
-Tasha-
-Frank Lloyd Wright
Old 03-09-2010, 08:32 PM   #11
culp7
HickTown
culp7's Avatar
classicparts.com is also a great source. idk if you knew bout it or not lol
and nice to see another high schooler on here!
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 03-09-2010, 09:04 PM   #12
WorkinOnIt
WorkinOnIt's Avatar
Yeah I've seen a few High school students on here.. But i don't think Ive seen any other girls in high school.
As for Clasicparts.com never heard of them but I'll look into them also Thanks
-Tasha-
-Frank Lloyd Wright
Old 03-10-2010, 01:37 AM   #13
72chevyfleet
Learning As I Go
72chevyfleet's Avatar
nice truck wow your the first girl in high school that i have seen on here or even heard of working on a truck thats a first whats your toyota look like? nice 4x4 too
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again)
72chevyfleet is offline   Reply With Quote
Old 03-10-2010, 02:38 AM   #14
WorkinOnIt
WorkinOnIt's Avatar
I 'm used to that, being the only girl who works on trucks.. I grew up with it
As for the yota, I'll get pics up. Its almost done except for some minor details Like the fact that my uncle wont let me finish it, so i'll put my effort into the chevy while i have time.
New update:
Found a guy with the fender and core support Working on details but i should get the parts soon.
Also have the 350 that came with the truck when my dad first bought it. I'll probably tear it down to see if its worth using over the new engine thats in it currently.
Also: Looking for a project name, Give me your ideas
-Tasha-
-Frank Lloyd Wright
Old 03-10-2010, 06:46 PM   #15
72chevyfleet
Learning As I Go
Ol' Blue or somethin like that
Old 03-10-2010, 08:42 PM   #16
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
wait, YOUR A GIRL WITH AN OLD TRUCK MY AGE!!
wow! there is alot of HS on here im a junior with a 68 lwb dubed blue goose. welcome theres alot of cool stuff on here! still cant belive your a girl with an old truck thats awesome!
John
1999 Toyota Tacoma 4x4
Old 03-10-2010, 10:20 PM   #17
Todersauce
For body parts you can try www.dansclassic.com down town and the swap meet is coming up too. Seems to be a lot of 67-72 trucks and parts around here too.
That truck is nearly twice your age! My project name suggestion Gold Digger.
Todersauce is offline   Reply With Quote
Old 03-10-2010, 11:23 PM   #18
WorkinOnIt
WorkinOnIt's Avatar
Calm down haha, Yes I'm a girl but that's not the point!!
The truck is a few years over twice my age lol
Ol' blue Just seems too plain..
And Gold Digger? Hmm I'll Think about it
but I don't think it fits
-Tasha-
-Frank Lloyd Wright
Old 03-10-2010, 11:43 PM   #19
culp7
HickTown
culp7's Avatar
damn cool, any progress?
255/70-15
___________
(oo)══╬══(oo)
Old 03-10-2010, 11:46 PM   #20
WorkinOnIt
WorkinOnIt's Avatar
This will be very sloww build thread. Im still in school right now and im managing softball girls for the next three months so i have to find time, and it wont happen right now..
-Tasha-
-Frank Lloyd Wright
Old 03-10-2010, 11:59 PM   #21
culp7
HickTown
culp7's Avatar
i feel yah there... wrestlin season has cut bout 80% out of my truck workin time... thank god it's over
255/70-15
___________
(oo)══╬══(oo)
Old 03-11-2010, 12:02 AM   #22
capev86
forgive that young buck.....that's all we can think about at that age. i remember being in my teens (i just turned 30). it is rare to find a young lady into rickety old trucks....so he does have an excuse for his over exuberance. most young ladies are only into expensive tuner cars or fast motorcycles...anything that is expensive and in style. check out the link (article) i posted. i thought it was funny, 'cause i started out with the family aries wagon (still have it) and it was an awesome first car. it was freedom any day of the week....something that was very rare in previous generations and young people just don't have respect or even a clue on how things used to be.
http://www.birminghamster.com/index032801.htm
Old 03-11-2010, 12:16 AM   #23
WorkinOnIt
WorkinOnIt's Avatar
That article is so true. Most girls just want everything hand to them, hell most guys do too.
But as for me I refuse to have a new car or truck. I Love old trucks, I'm not into those stupid nitro cars, sure there cool looking and fast but I know for a fact I would kill myself.. I get my speed fix from the quads, I dont need to go fast on the road, which i already go too fast as it is
Plus, I don't trust new cars, at the risk of sounding old fashion, They just don't build em like they used to. :P
Obviously I'm Kind of a different breed, But I will always find it funny that it's such an odd thing to see a hs girl on here.
-Tasha-
-Frank Lloyd Wright
Old 03-11-2010, 12:39 AM   #24
EA69TRK
EA69TRK's Avatar
Its always great to see more kids my own age into these trucks and this site is full of helpful and knowledable people who have no problem answering any and all questions no matter how stupid you think it is. You should check out this thread to see some other HS owners http://67-72chevytrucks.com/vboard/s...d.php?t=334086
O where are my manners from Nor Cal.
1969 Chevy C10 Short Step -Project
2005 GMC Sierra Crew Cab 1500 -DD
2017 Laguna Orange Roadglide - Good Weather DD
EA69TRK is offline   Reply With Quote
Old 03-11-2010, 03:45 AM   #25
threeonthetree
threeonthetree's Avatar
Nice truck. Ha
Fire that 350 yet?
Do anything? Got it inside?
Pics of engine cab floor box floor.
3/4= 8 bolts??
Also I never would have pictured a girl running a ol rusty chevy 3/4 ton.
But sweeet
Good luck with the project.
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
